ilogic rules setting
hey im trying to set a rule in which
i have 2 iparts that i can change the length of
i want a rule where if i change one of them it changes the other to fit with it
am i going about this the right way trying to set a ilogic rule or is there a easier way ?
xiaodong_liang
Autodesk Support
Autodesk Support
I am not clear how your workflow could be, and how you define the relationship of one iPart member and the other But probably it would be more helpful if you define a parameter and set the values of iPart member follows this parameter. e.g.as the attached snapshot, the three iPart members follow one param. If the param changes, all iPart member will update. So in this perspective, if you set the first member follows the param, the values of other members could follow with an equation of the param.
