iLogic rule
iLogic rule
iLogic rule
hey everyone.
today i wanted to make a code to read some values from an excel, but when i'm running it i get the error that:
"Error in rule: Parameter, in document: Layout.iam
Excel cell not found (bad cell address?): "A"
I have used the following funtion
Dim A = GoExcel.CellValue("A" & i)
The excel is saved in the same folder as the assembly and in the beginning i have used a function to open the excel data.
mcgyvr
Can you post the excel file and complete code? More of the code at the very least..
Have you tried replacing the variable with a fixed cell value to ensure that works first? (walk before you run kind of stuff)
Where have you defined which excel file it should be reading from,etc...?
GoExcel.Open(Link, "Tabelle1")
Planexo = GoExcel.CellValue("F3")
Planex1 = GoExcel.CellValue("F4")
Planex2 = GoExcel.CellValue("F5")
Planex3= GoExcel.CellValue("F6")
Planex4= GoExcel.CellValue("F7")
Planex5= GoExcel.CellValue("F8")
Planex6= GoExcel.CellValue("F9")
Planey0= GoExcel.CellValue("H3")
Planey1 = GoExcel.CellValue("H4")
Planey2 = GoExcel.CellValue("H5")
Planey3 = GoExcel.CellValue("H6")
Planey4 = GoExcel.CellValue("H7")
Planey5 = GoExcel.CellValue("H8")
Planey6 = GoExcel.CellValue("H9")
'[length of arrays
For Each xVar In PlaneX
	lenX = lenX + 1
Next
For Each yVar In PlaneY
	lenY = lenY + 1
Next
'[sorting the array with distance
For j = 0 To lenX - 2
	For h = 0 To lenX - 2
		If PlaneX(h)>PlaneX(h+1)
			temp = PlaneX(h)>PlaneX(h+1)
			PlaneX(h + 1) = PlaneX(h)
			PlaneX(h) = temp
		End If
	Next
Next
For j = 0 To lenY - 2
	For h = 0 To lenY - 2
		If PlaneY(h) >PlaneY(h + 1)
			temp = PlaneY(h) >PlaneY(h + 1)
			PlaneX(h + 1) = PlaneY(h)
			PlaneY(h) = temp
		End If
	Next
Next
While Bool
	If String.Compare(Left(A, 2), "No") = 0
		If String.Compare(Left(Right(A, 2), 1), "x") = 0
			Plane.Add(i)
			PlaneName.Add("Ebene" & Right(A, 2))
			NumberOfPlane.Add(GoExcel.CellValue("B" & i))
			xy.Add("x")
		Else If String.Compare(Left(Right(A, 3), 1), "x") = 0
			Plane.Add(i)
			xy.Add("x")
		Else If String.Compare(Left(Right(A, 2), 1), "y") = 0
			Plane.Add(i)
			xy.Add("y")
		Else If String.Compare(Left(Right(A, 3), 1), "y") = 0
			Plane.Add(i)
			xy.Add("y")
		Else If String.Compare(Right(A, 8), "Förderer") = 0
			Bool = False
		End If
	End If
	If i = 1000
		Bool = False
	End If
	i=i+1
End While
this is the code that i wrote. the excel table is defined in parameters a text file under the name "Link".
the program opens the data, but it can't read the columm A for some reason.
This is the first time that this happens to me.
SharkDesign
Did you try restarting your computer?
I've had loads of issues with Excel and iLogic before. I've spent hours trying to fix it, then I reboot my computer and magically it just works again.
  Inventor Certified Professional
A.Acheson
I always start with a simple cell reference to ensure you can write or read from it. This ensures correct linkage with excel.
Dim A = GoExcel.CellValue("A" & 1)
‘or
Dim i as integer
i=1
Regards
Alan
