ILogic rule works in assembly
patryk_walkusz
patryk_walkusz
I created a form for an IPT file, and when I open it, I made a rule to choose whether to open the form or not. When I open an IAM file with this IPT file, I also see this rule.
Can I add something to make this rule appear only when opening the IPT file?
my rules:
Dim result As DialogResult
result = MessageBox.Show("Do you want to open the form for editing?", "Edit Glass - Form", MessageBoxButtons.YesNo)
If result = DialogResult.Yes Then
    ' Kod do otwarcia formularza
    iLogicForm.Show("GlassEdit")
Else
    ' Kod, gdy użytkownik wybierze "Nie"
I put this rule after open document:
Andrii_Humeniuk
Hi @patryk_walkusz . You can add a document type check to your rule. Example:
If Not ThisApplication.ActiveDocumentType = DocumentTypeEnum.kPartDocumentObject Then Exit Sub
Else
Or place your rule in the event trigger of the parts:
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
