iLogic Rule - View Representations - Toggling Component Visibility Within Assembly, Based on Custom iProperty Value
Cadderman
Cadderman
Hi All,
I have a fabrication template which contains patterns that update to suit overall fabrication width, length and height.  As quantities of components vary and this template will be copied and given new names, I need a good iLogic code that can keep the view reps right.
A typical fabrication will contain four view representations, such as:
Category 1 - Primary
Category 2 - Secondary
Category 3 - Tertiary
Category 4 - Cosmetic
I have given all parts within the assembly a custom iproperty, so they can be identified.
I would like a code that can be operated from assembly level.  This code would ensure the following:
  • When view representation "Category 1" is activated, only items with Custom iproperty "Category" value = 1
  • When view representation "Category 2" is activated, only items with Custom iproperty "Category" value = 1 and 2
  • When view representation "Category 3" is activated, only items with Custom iproperty "Category" value = 1 and 2 and 3
  • When view representation "Category 4" is activated, only items with Custom iproperty "Category" value = 1 and 2 and 3 and 4
Is this possible?
WCrihfield
I am assuming we are just talking about top level components here, because we are dealing with main assembly view rep and simple component visibility.  I also assume that I do not need to filter by document type, so every top level component, whether it be a part or sub assembly, will have that custom iProperty.  I also assume that the value of that custom property will always have a value, and it will be in Integer form, not String (quoted number).  Also, I don't know if we are dealing with ModelStates (set to something other than 'Master')...if so, the iProperty snippet might not work.
I think that this may work for you.
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "iLogic")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	oADef = oADoc.ComponentDefinition
	oVRep = oADef.RepresentationsManager.ActiveDesignViewRepresentation
	oOccs = oADef.Occurrences
	Dim oValues As New List(Of Integer)
	Select Case oVRep.Name
	Case "Category 1"
		oValues.Add(1)
		ToggleOccVis(oOccs, oValues)
	Case "Category 2"
		oValues.AddRange({1,2})
	Case "Category 3"
		oValues.AddRange({1,2,3})
	Case "Category 4"
		oValues.AddRange({1,2,3,4})
	End Select
End Sub
Sub ToggleOccVis(oComps As ComponentOccurrences, oVals As List(Of Integer))
	For Each oComp As ComponentOccurrence In oComps
		oCat = iProperties.Value(oComp.Name, "Custom", "Category")
		Dim oMatch As Boolean = False
		For Each oVal In oVals
			If oCat = oVal Then
				oMatch = True
				If Not oComp.Visible Then oComp.Visible = True
		Next
		If Not oMatch Then
			If oComp.Visible Then oComp.Visible = False
	Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
