iLogic Rule to report missing or unavailable components
05:33 AM
I'm using iLogic to build a configurator and everything is working perfectly if I have all the componets available.
However, is there a way to use iLogic in this example:
Assume I have a bolt, nut and washer in an assembly based on 1/2" sizes. I then change the sizes to 1", the bolt and nut update to 1" but I do not have a washer modeled for 1". Is there a way to use iLogic to report that the washer is not available without causing an error or only updating the bolt and nut and ignoring the washer.
