iLogic Rule to report missing or unavailable components
I'm using iLogic to build a configurator and everything is working perfectly if I have all the componets available.
However, is there a way to use iLogic in this example:
Assume I have a bolt, nut and washer in an assembly based on 1/2" sizes. I then change the sizes to 1", the bolt and nut update to 1" but I do not have a washer modeled for 1".  Is there a way to use iLogic to report that the washer is not available without causing an error or only updating the bolt and nut and ignoring the washer.
jdkriek
If I am reading your post correctly, you just want to check if a specific component exists, right?
iLogic is basically VB.NET so you can use File.Exists()
Dim sFilePath As String = "c:\temp\test.ipt"
If System.IO.File.Exists(sFilePath) Then
	MsgBox("File Exists")
Else
	MsgBox("File Does Not Exist")
End If
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
