iLogic rule to create iParts from an Excel
Geveke
Geveke
Hi all,
I want to create a standard iPart with user parameters which are loaded through an iLogic rule from an Excelfile.
The part has for example the following user parameters: Height1, Width2, Length3.
The Excelsheet on sheet1, Cell A1: Height1, Cell B1: Width2 Cell C1: Length3
The number of rows can be as little as lets say 3 up to 200 rows.
How should the iLogic rule look like in order to make this work?
Thanks in advance!
chandra.shekar.g
Autodesk Support
Autodesk Support
@Geveke,
Hoping that suggestions in the below blog link may be helpful.
https://adndevblog.typepad.com/manufacturing/2013/07/inventor-api-ipart-functionality.html
https://forums.autodesk.com/t5/inventor-customization/generate-ipart-files-using-ilogic-vba/td-p/580...
If not, please provide UI steps to simulate in iLogic.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Geveke
Hi Chandra,
Thanks for your reply.
Going to try to get this work with your suggestions.
If not, i'll get back to you.
Thanks so far.
