Ilogic rule to change surface body properties line types
Message 1 of 12
HI all..
I have a lot of multi bodies parts that, I have a sweeped surface bodies, where I in IDW use surface bodies as centerline. I want to make a ilogic rule to change this suface bodies lines properties in IDW as default. That mean, when I make a view the surface bodies properties should change to centerline line types. thanks in advance.
RG
MDN
Replies (11)
Message 2 of 12
Hi all,
Is this task really impossible?  I need some helps here..
Message 3 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please provide to sample part (multiple bodies) to test and manual steps to change line types of surface bodies in IDW? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 12
Hereby attached some examples.
It's would be nice, if is possible to make surface bodies as default change the properties to centerline.
Thanks in advance.
RG
MD
Message 5 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
As center lines are derived from surface body,  it is appeared as Edge object in drawing. All edge geometry in drawing can be used to change the line type.
Try below iLogic code to change line type.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oView As DrawingView
oView = oSheet.DrawingViews.Item(1)
Dim oCurve As DrawingCurve
For Each oCurve In oView.DrawingCurves
	If oCurve.ModelGeometry.Type = ObjectTypeEnum.kEdgeObject Then
	    oCurve.LineType = LineTypeEnum.kChainLineType
	    oCurve.LineWeight = 0.018
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 12
Hi
Thanks you for your reply.
Now I have added the ilogic rule i the idw.
I changed the view with new pipes with surface bordies and run the rule, nothing happening, See Pic.
Is there something I missing?
RG
MD
Message 7 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
iLogic code is working for previously attached drawing. To demonstrate this, screencast video is prepared and uploaded to below link.
https://autode.sk/2QRL1Xd
To test the same, can you please provide drawing document? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 12
Hi
Thanks for the video.
I have tested with the same IDW I posted to you, it works also fine with the same view. But it do not works, If you just places a new view, example the same test pipe in to a new view and run the rule, and the line do not change. How come?
* The difference with the IDW I posted with the IDW I working on is instead of the IPT, I places the view with the pipes IAM. with representation view. see PIC. Maybe a Little modification in rule will work.
again thanks in advance.
RG
MD
Message 9 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that below iLogic code may be helpful.
Dim oSheet As Sheet
	If oCurve.ModelGeometry.Type = ObjectTypeEnum.kEdgeObject Or oCurve.ModelGeometry.Type = ObjectTypeEnum.kEdgeProxyObject Then
Next
Otherwise, please provide IDW with assembly file to test. Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 12
Hi
Thanks you..
I'm so happy that works now on IDW's I'm working on. But only the first view change the line type, on other views if I change the representation view and run the rule not thing change.
I try to copy the first view and so change the pipe with no success. I hope you have a solution for that. We are close..
only the view (marked) works not the rest of views see PIC.
RG
MD
Message 11 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try this,
Dim oSheet As Sheet
For Each oView In oSheet.DrawingViews
	Next
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 12 of 12
Many thanks you for your helps, It's working perfect now.
My task now is trying to understand what the codes stand for..Smiley Very Happy
RG
MD
