iLogic rule to change drawing view layer
Message 1 of 10
Hello all,
I am trying to piece togther some code for an ilogic rule. This rule should look for a drawing view that is a flat pattern, if it finds one it should change the object layer to our "CNC" layer.
Is this possible?
Any suggestions are welcome.
Replies (9)
Message 2 of 10
jdkriek
If I understand you correctly, this should be the ticket:
' JDK 2013
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oView As DrawingView
	For Each oView In oSheet.DrawingViews
		' If it's a flatpattern view
		If oView.IsFlatPatternView = True Then
			' Get Layers
			Dim oLayers As LayersEnumerator = oView.Parent.Parent.StylesManager.layers
			' Get CNC layer
			Dim oLayer As Layer = oLayers.Item("CNC")
			' Get lines
			Dim oCurves As DrawingCurvesEnumerator = oView.DrawingCurves()
			Dim oCurve As DrawingCurve
				' For each line
				For Each oCurve In oCurves
					' Change the layer
					oCurve.Segments.Item(1).Layer = oLayer
				Next
		End If
	Next
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 3 of 10
This worked great! Thanks for your help!!
Message 4 of 10
jdkriek
You're welcome 😉
Glad it worked for you.
Jonathan D. Kriek
Message 5 of 10
garrison34
I used the same rule you provided but, I'm running into issues where is changes all the layers on my flat patterns. I would like my bend lines, centers, and any other layers for my flat to be on there separate layers and change when using this rule. Is there a way to do this?
Message 6 of 10
garrison34
Message 7 of 10
dparks2265
Jordan
Reply Test
Message 8 of 10
            If Not (oview.breakoperations.count > 0) Then
            ' Get Layers
            Dim eLayer As LayersEnumerator = oView.Parent.Parent.StylesManager.layers
            ' Get CNC layer
            Dim oLayer As Layer= eLayer.Item("CNC")
            ' Get Visible Layer
            Dim oVisibleLayer As Layer= eLayer.Item("Visible (ANSI)")
            ' Get lines
            Dim oViewCurves As DrawingCurvesEnumerator = oView.DrawingCurves()
                ' For each line
                For Each oCurve In oViewCurves
                    ' Change the layer only if it is an object edge
                    If oCurve.Segments.Item(1).Layer Is oVisibleLayer Then
                    End If
                Next
            End If
        End If
    Next
Refer to your Drawing Standards setup for which layer your flat pattern is placed
into. If needed, substitute your flat pattern object layer name for the
"Visible (ANSI)" shown above.
Message 9 of 10
Is it possible to adapt this code to change the layer of a line only if the line is 7.99mm long?
Also, is it possible to change the layer of a circle only if the circle is 3.99mm dia?
I hope so as this would save me a huge amount of time.
Thanks in advance
M
Message 10 of 10
Thanks in advance
M
