iLogic Rule to ask YES or No for .DXF export when saving .IDW
Message 1 of 23
Haha, little monday morning humour,
So I would like help with a simple rule if anyone has a few moments,
Basically, some of my drawings require a dxf for cnc purposes.
Not all my drawings, so I don't need a dxf for every drawing, just some.
It would be much quicker to have a rule that prompts a message box after I press save, stating something like
Do you require a .DXF?
 Yes    or     No.
I currently have a rule that saves all my .idw's as pdf, I am not sure if I should have a separate rule or if it can be part of the same rule. The pdf rule is triggered by a save as well.
'Save PDF with options
path_and_namePDF = ThisDoc.PathAndFileName(False) ' without extension
PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
'oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
'Set the destination file name
oDataMedium.FileName = path_and_namePDF & ".pdf"
On Error Goto handlePDFLock
'Publish document.
Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Exit Sub
handlePDFLock:
MessageBox.Show("PDF could not be saved, most likely someone else has it open.", _
"No PDF for you " & ThisApplication.GeneralOptions.UserName & "!")
Resume Next
Thanks for any input!!
Replies (22)
Message 21 of 23
your posts are always very helpful and thank you for sharing.
I have a question, I would like to convert to DXF only sheet 2, but with the rule over always creates all sheets, how can I do?
Where am I wrong?
 my rule
oPath = "C:\Users\luca\Documents\DIS DA SPEDIRE\esportati in automatico\"
oFileName = ThisDoc.FileName(False) 'without extension
If iProperties.Value(modelName,"Project", "Revision Number") = "" Then
iProperties.Value("Project", "Revision Number")= "--"
End If
If Not iProperties.Value(modelName,"Project", "Revision Number") = "" Then
iProperties.Value("Project", "Revision Number")= iProperties.Value(modelName,"Project", "Revision Number")
End If
If iProperties.Value(modelName,"Status", "Status") = "" Then
iProperties.Value("Status", "Status")= "--"
End If
If Not iProperties.Value(modelName,"Status", "Status") = "" Then
iProperties.Value("Status", "Status")= iProperties.Value(modelName,"Status", "Status")
End If
oRevision = iProperties.Value("Project", "Revision Number")
oStatus = iProperties.Value("Status", "Status")
txt5=iProperties.Value("Summary", "Keywords")
' Get the dxf translator Add-In.
Dim dxfAddIn As TranslatorAddIn
dxfAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
Dim oContext As TranslationContext
' Create a NameValueMap object
Dim oOptions As NameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
'Define the drawing
        Dim oDrawing As DrawingDocument
        oDrawing = ThisDoc.Document
        Dim oSheet As Sheet
        Dim lPos As Long
        Dim rPos As Long
        Dim sLen As Long
        Dim sSheetName As String
         sSheetName= "SAGOMA"
        Dim sSheetNumber As Integer
        'step through each drawing sheet
Dim Response As MsgboxResult
        For Each oSheet In oDrawing.Sheets
            Response = MsgBox("Yes = Save or No = Continue to next Sheet?", MsgBoxStyle.YesNo, "Question")
            If Response = MsgBoxResult.Yes Then
                'find the seperator in the sheet name:number
                lPos = InStr(oSheet.Name, ":")
                'find the number of characters in the sheet name
                sLen = Len(oSheet.Name)
                'find the sheet name
                sSheetName = Left(oSheet.Name, lPos - 1)
                'find the sheet number
                sSheetNumber = Right(oSheet.Name, sLen - lPos)
                    End If
        Next
' Check whether the translator has 'SaveCopyAs' options
If dxfAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "M:\Ufficio Tecnico\INVENTOR STANDARD\Design Data 2013\DWG-DXF\DWG OK2 exportdwg .ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
oFolder ="C:\Users\luca.leocata\Documents\DIS DA SPEDIRE\esportati in automatico\"
oDataMedium.FileName = oFolder & oFileName & "  " & oStatus &  "  Rev. " & oRevision & "  " & " " & txt5 & ".dxf"
'Publish document.
dxfAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
thank's
Message 22 of 23
GosponZ
Ok here is code that I'm using daily, yes is to create dxf from sheet and no is not. Place path where you want this dxf's to go.
oPath = ThisDoc.Path
       oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
       'Define the drawing
       Dim oSheet As Sheet
       Dim lPos As Long
       Dim rPos As Long
       Dim sLen As Long
End If
ActiveSheet = ThisDrawing.Sheet(oSheet.Name)
     'get DXF target folder path
               oFolder = "N:\YOUR PATH HERE DXF FILES"
               'Set the DXF target file name
               oDataMedium.FileName = oFolder & "\" & sSheetName & sSheetNumber & ".dxf"
               MessageBox.Show("DXF SAVED TO: " & oDataMedium.FileName, "DXF Saved", MessageBoxButtons.OK)
               'Publish document
               oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
           End If
       Next
Message 23 of 23
aronmatheus
I Found this ruler:
But I would change because the external line of the sheet it don't go out when I print.
' Get the DXF translator Add-In.
Dim DXFAddIn As TranslatorAddIn
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
strIniFile = "G:\Inventor 2016\iLogic\dxf.ini"
End If
oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".dxf"
'Publish document.
'Launch the dxf file in whatever application Windows is set to open this document type with
'i = MessageBox.Show("Preview the DXF file?", "Title",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
