ilogic rule suddenly not working
Hi, wonder if anyone can help...
I have an ilogic rule to save a dxf that has been used for probably 5 years now and the code is unchanged.
Suddenly and for no reason I am getting this error:
We have 6 people working in the design department and this has happened to one other colleague (he repaired it by reinstalling inventor) but the others are all fine using the exact same rule.
Anyone else had this error before and know how to fix it?
Cheers, Finn
GeorgK
Can you share the code and drawing?
Here are the part and drawing files.
And the code is here:
SyntaxEditor Code Snippet
strFolder = ThisDoc.WorkspacePath() & "\Layouts and Details\DXFs\" & ThisDoc.FileName(False)
ThisDoc.Document.SaveAs(strFolder & (".dxf") , True)
MessageBox.Show("DXF file created/updated", "What a lovely drawing!")
And I have checked that the folder it is trying to save to definitely exists
Twist to the story,
I have just replaced my template file with one from a colleague - important to note here that the files are the exact same - and now it is working fine.
I double checked and the ilogic code is identical.
Why would this happen? I am certain it is not a problem with the ilogic.
