iLogic Error: Object reference not set to an instance of an object
Brian_Price
Brian_Price
I am working on moving some rules I have been using to  external, so that I don't have to go through and update each rule in each part/assembly.
I am stuck with the error: "Object reference not set to an instance of an object".
Here's the other info with the error message.
System.NullReferenceException: Object reference not set to an instance of an object.
at iLogic.CadAssemblyUtil.FindComponentOccurrence(Document rootDoc, Object compoName, Boolean topLevelOnly, Boolean inTopLevelContext)
at iLogic.CadCompoOrDoc..ctor(Document rootDoc, Object oName)
at iLogic.ParamDynamicFinder.GetParameterInCompoOrDoc(Object compoOrDocName, String paramName)
at iLogic.ParamDynamic.set_Item(Object compoOrDocName, String paramName, Object value)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
SyntaxEditor Code Snippet
Parameter("SHELL PL1 - A:1", "ShellPL1ID")=Parameter("ShellPL1ID")
I have narrowed it down to just this parameter change.
The weird thing is, is that the error pops up and then Inventor proceeds to change the part according to the rule, so the rule is actually working. It just keeps throwing up an error before it changes it though.
The part it is changing is a just circular contour flange. The part is pretty simple and if I add this rule to the assembly with the part in it. It works just fine with no errors.
Thanks for the help.
Lewis.Young
At the start of the code you can try adding this:
On Error Resume Next
If in doubt, post the whole code here and i will try have a proper look
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
Brian_Price
It still displays the error and does not move to the next function as there is none.
