iLogic - rule process order
Hi All,
I have the following piece of code that is not running in the order I would like it to.
It should basically change all hole settings to 'Major', run 'Analyze Interference', then changed all hole settings back to 'Tap Drill'.
But it runs 'Analyze Interference' first then changes the hole settings, I don't understand why.
I'm not sure how Sub Main works, my guess is that I should be calling the hole setting pieces of the code as Sub's, is that correct?
Sub Main
' ********** References *********
' kThreadMajorDiameter 21761
' kThreadMinorDiameter 21762
' kThreadPitchDiameter 21763
' kThreadTapDrillDiameter 21764
' ********** Declarations
iLogicVb.UpdateWhenDone = True
Dim partDoc As PartDocument = TryCast(ThisDoc.Document, PartDocument) ' Set Variable if the Current Doc Type is Part
Dim assemDoc As AssemblyDocument = TryCast(ThisDoc.Document, AssemblyDocument) ' Set Variable if the Current Doc Type is Assembly
' ********** For a Component File
If (partDoc IsNot Nothing) Then ' If this is a part document
    partDoc.ModelingSettings.TappedHoleDiameter = 21761 ' Set the Tapped Hole Type
' ********** For an Assembly File
If (assemDoc IsNot Nothing)Then ' If this is an Assembly document
    assemDoc.ModelingSettings.TappedHoleDiameter = 21761 ' Set the Tapped Hole in the Assembly File
    Dim docFile As Document ' Declare a Variable for each referenced document to loop thru
    i = 0
    For Each docFile In assemDoc.Allreferenceddocuments ' For all the documents referenced in the assembly
        If docFile.IsModifiable = True Then ' If the document is able to be modified
            Dim RefassemDoc As AssemblyDocument = TryCast(docFile, AssemblyDocument) ' Set Variable if the Current Doc Type is Part
            Dim RefpartDoc As PartDocument = TryCast(docFile, PartDocument) ' Set Variable if the Current Doc Type is Assembly
            If (RefpartDoc IsNot Nothing) Then ' If this Doc is a Part
                RefpartDoc.ModelingSettings.TappedHoleDiameter = 21761 ' Set the Tapped Hole Type
            Else ' This Doc must be an assembly
                Dim RefAsmDoc As AssemblyDocument = TryCast(docFile, AssemblyDocument) ' Set Variable if the Current Doc Type is Part
                Try
                RefAsmDoc.ModelingSettings.TappedHoleDiameter = 21761 ' Set the Tapped Hole Type
                Catch
                End Try
    Next
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
' Add each occurrence in the assembly to the object collection.
Dim oCheckSet As ObjectCollection
oCheckSet= ThisApplication.TransientObjects.CreateObjectCollection
Dim oOcc As ComponentOccurrence
For Each oOcc In oAsmCompDef.Occurrences
     oCheckSet.Add (oOcc)
Next
' Call the AnalyzeInterference method, passing in a single
' collection. This will cause it to compare everything against
' everything else.
Dim oResults As InterferenceResults
oResults = oAsmCompDef.AnalyzeInterference(oCheckSet)
Dim oResult As InterferenceResult
Dim iCount As Integer
iCount = 0
volume = InputBox("Set the minimum volume value (cm^3) to be excluded from the results", "Volume Threshold", "0.1")
For Each oResult In oResults
    If oResult.Volume > volume Then
        iCount = iCount + 1
Next
' Display the results of the interference.
MessageBox.Show(iCount & " Interferences found ","iLogic")
iCount = 0
        iCount = iCount + 1
        oResult.OccurrenceOne.SetRenderStyle(100609,oAsmDoc.RenderStyles.Item("Yellow"))
        oResult.OccurrenceTwo.SetRenderStyle(100609,oAsmDoc.RenderStyles.Item("Magenta"))
        MessageBox.Show("     " & FullOccurrenceName(oResult.OccurrenceOne) & "      (colored yellow)" _
        & vbLf & "interferes with " _
        & vbLf & "     " & FullOccurrenceName(oResult.OccurrenceTwo) & "      (colored magenta)" _
        & vbLf & "" _
        & vbLf & "Volume: " & Round(oResult.Volume,5) & " cm^3", _
        " Interference "& iCount)
        oResult.OccurrenceOne.AppearanceSourceType = 100612 'kPartAppearance
        oResult.OccurrenceTwo.AppearanceSourceType = 100612 'kPartAppearance
Next
    partDoc.ModelingSettings.TappedHoleDiameter = 21764 ' Set the Tapped Hole Type
    assemDoc.ModelingSettings.TappedHoleDiameter = 21764 ' Set the Tapped Hole in the Assembly File
    i = 0
                RefpartDoc.ModelingSettings.TappedHoleDiameter = 21764 ' Set the Tapped Hole Type
                Try
                RefAsmDoc.ModelingSettings.TappedHoleDiameter = 21764 ' Set the Tapped Hole Type
                Catch
                End Try
    Next
End Sub
' Used to display the full path of an occurrence. This is the path of the
' occurrence within the assembly structure.
Private Function FullOccurrenceName(Occ As ComponentOccurrence) As String
Dim i As Integer
For i = 1 To Occ.OccurrencePath.Count
If i = 1 Then
FullOccurrenceName = Occ.OccurrencePath.Item(i).Name
Else
FullOccurrenceName = FullOccurrenceName & "\" & Occ.OccurrencePath.Item(i).Name
Next
End Function
NSBowser
It appears that the code is operating in the correct order as you have described.
The setting of .TappedHoleDiameter = 21761 which appears in the first few blocks would be setting the holes to the Major Diameter.
All this occurs prior to the Analyze interference is run.
The only thing I can think, is that the change to the TappedHoleDiameter is not physically affecting the model before the Interference check runs.
Try adding a 'Document Update' after setting the Major diameters but before the interference checks.
Example:
oAsmDoc.Update2(True)
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
Genius! Document update did the trick Smiley Happy
NSBowser
Good, I'm glad the solution worked for you.
Please consider using the 'Mark as Solution' feature so that your post indicates it was solved and so future users with similar issues can quickly find the answers they need.
Best of Luck
