Get features of model in a Inventor drawing view
I am trying to get features of the model attached to a view in Inventor drawing (Inventor 2014)
I tried the following code and it is failing.
Private Sub GetFeaturesOfModelFromOccurence(oFrontView As DrawingView)
    Try
          ' Get the assembly document that is attached to the view (assuming assembly model in the view)
          Dim oDoc As AssemblyDocument
          oDoc = InventorApplication.Documents.ItemByName(oFrontView.ReferencedDocumentDescriptor.FullDocumentName)
          ' Get all the components in the assembly uisng component definition
           Dim compDef As AssemblyComponentDefinition
           compDef = oDoc.ComponentDefinition
           Dim compOccurences As ComponentOccurrences
           compOccurences = compDef.Occurrences
           Dim compOccurence As ComponentOccurrence
          For Each compOccurence In compOccurences
                ' Get the Inventor Document assocaited with the component occurence
                Dim partDoc As PartDocument
                ' The following statement fails - I think the argument ItemByName expects is FullDocumentName and I am passing Name
                ' How to get the document from component occurrence?
                partDoc = InventorApplication.Documents.ItemByName(compOccurence.Name)
                Dim partCompDef As PartComponentDefinition
                partCompDef = partDoc.ComponentDefinition
                Dim compPartFeatures As PartFeatures
                compPartFeatures = partCompDef.Features
                For Each feat As PartFeature In compFeatures
                          MessageBox.Show(" Feature name >" + feat.Name + "<")
                 Next
          Next
     Catch ex As Exception
            MessageBox.Show("ERROR : " + ex.Message + System.Environment.NewLine)
            MessageBox.Show(ERROR : " + ex.StackTrace + System.Environment.NewLine)
      End Try
End Sub
wayne.brill
You can get the document of the occurrence using the Document property of the ComponentDefinition. Here is a VBA snippet:
   Dim oDef As ComponentDefinition
            Set oDef = occ.Definition
            Dim oDoc As Document
            Set oDoc = oDef.Document
            Debug.Print oDoc.FullDocumentName
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Hi Wayne,
   Tried your suggestion. But I am getting the following error in the statement
            partDoc = InventorApplication.Documents.ItemByName(oCompDoc.FullDocumentName)
            ERROR : Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
The following is the modified code based on your reply.
    Try
         Dim count As Integer = 1
                oDef = compOccurence.Definition
                Dim oCompDoc As Document
                oCompDoc = oDef.Document
                 partDoc = InventorApplication.Documents.ItemByName(oCompDoc.FullDocumentName)   ' ERROR occurs with this statement
                 For Each feat As PartFeature In compPartFeatures
                 Next
            Next
        End Try
End Sub
Regards
PV Subramanian
wayne.brill
Hi PV,
Your code works ok for me. I am testing with a simple assembly with one part occurrence.
Does your assembly have sub assemblies that are not ipt files but iam files? That would cause that error because it is trying to case a assembly document to a part document.
Also I am not sure why you are using Documents.ItemByName(). The code already has the document.
You could test the Document DocumentType
Here is some code I added to test:
                'WB added
                Dim partDoc As PartDocument = Nothing
                Dim asmDoc As AssemblyDocument = Nothing
                If oCompDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                    partDoc = oCompDoc
                ElseIf oCompDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                    asmDoc = oCompDoc
                    'If this is hit need to go to next occurrence as partDoc is Nothing and code below will fail
                    Continue For
                'WB end added
If this does not help upload an assembly I could use to research the problem. (need all the files of the assembly)
Wayne
Wayne Brill
