iLogic rule open part from drawing, wont trigger event of part
peter.ensing
peter.ensing
Question:
I am trying to update my part from the drawing.
The part contains 2 rules that run on event trigger when opening and saving the part.
The part gets parameters from an Excel database.
I want to be opening my drawing and than update the part automatically with a new rule.
This part of the rule opens, saves and closes the part but it wont trigger the rule of the part.
I cant trigger it with the "Run other" types in the edit rule list.
Who has got an idea how to make this work?
(Drawing filename=Part filename= Part number)
SyntaxEditor Code Snippet
Try
 doc = ThisDoc.Document
 Dim oFD As FileDescriptor
 Dim CurFileName As String
 'get the path and file name of the selected item
CurFileName = doc.FullFileName
'defines backslash as the subdirectory separator
Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
'get the path of the folder containing the file
Folder_Location = Left(CurFileName, Len(CurFileName) - Len(Name)-4)
 ThisDoc.Launch(Folder_location & ".ipt")
 ThisDoc.Save
 ThisApplication.ActiveDocument.Close(True)
Catch
End Try
Mark.Lancaster
@peter.ensing
Programming needs, questions, or issue should be asked in the Inventor Customization Forumhttps://forums.autodesk.com/t5/inventor-customization/bd-p/120.  I will have the moderator relocate it there to better suit your needs.
Mark Lancaster
