iLogic rule not running automaticly
Hello all fellow Inventor users!
Being new to this forum and new to the usage of iLogic bear with me if I do things stupidly and feel free to advice me in the right direction.
I am working on a assembly with multiple rings whereby I can change the diameter of these rings through selecting a DN size using a form. The rings are made through skeletal modelling and every ring has their own diameter parameter. Then I also made a text parameter for every ring with the different DN sizes.
I first wrote out the code completely and then the model would update automaticly when changing the form parameters. I wanted to reduce the code by creating a loop but now I have run to run the rule and update de model by clicking manually.
I hope someone has a solution for me!
For x =1  To 12
If Parameter("dn" & x) = "DN45  ⌀51" Then
	Parameter("DIA" & x) = 76
ElseIf Parameter("dn" & x) = "DN50  ⌀60" Then
Parameter("DIA" & x) = 83
ElseIf Parameter("dn" & x) = "DN65  ⌀76" Then
Parameter("DIA" & x) = 99
ElseIf Parameter("dn" & x) = "DN80  ⌀89" Then
Parameter("DIA" & x) = 110
ElseIf Parameter("dn" & x) = "DN90  ⌀102" Then
Parameter("DIA" & x) = 126
ElseIf Parameter("dn" & x) = "DN100  ⌀114" Then
Parameter("DIA" & x) = 140
ElseIf Parameter("dn" & x) = "DN105  ⌀121" Then
Parameter("DIA" & x) = 148
ElseIf Parameter("dn" & x) = "DN125  ⌀139" Then
Parameter("DIA" & x) = 173
ElseIf Parameter("dn" & x) = "DN145  ⌀152" Then
Parameter("DIA" & x) = 190
ElseIf Parameter("dn" & x) = "DN150  ⌀168" Then
Parameter("DIA" & x) = 207
ElseIf Parameter("dn" & x) = "DN200  ⌀219" Then
Parameter("DIA" & x) = 255
Next
johnsonshiue
Hi! The alternative is to use Select Case. But, you won't save much code. It is because you do have unique cases and each case has a unique action.
Many thanks!
Software Test Engineer
Would this solve the problem of the rule not running automaticly? Also I'm not super familiar with the function select case. Maybe if you could show me a part of the code.
Thanks in regards
