iLogic rule not running automaticly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all fellow Inventor users!
Being new to this forum and new to the usage of iLogic bear with me if I do things stupidly and feel free to advice me in the right direction.
I am working on a assembly with multiple rings whereby I can change the diameter of these rings through selecting a DN size using a form. The rings are made through skeletal modelling and every ring has their own diameter parameter. Then I also made a text parameter for every ring with the different DN sizes.
I first wrote out the code completely and then the model would update automaticly when changing the form parameters. I wanted to reduce the code by creating a loop but now I have run to run the rule and update de model by clicking manually.
I hope someone has a solution for me!
For x =1 To 12 If Parameter("dn" & x) = "DN45 ⌀51" Then Parameter("DIA" & x) = 76 ElseIf Parameter("dn" & x) = "DN50 ⌀60" Then Parameter("DIA" & x) = 83 ElseIf Parameter("dn" & x) = "DN65 ⌀76" Then Parameter("DIA" & x) = 99 ElseIf Parameter("dn" & x) = "DN80 ⌀89" Then Parameter("DIA" & x) = 110 ElseIf Parameter("dn" & x) = "DN90 ⌀102" Then Parameter("DIA" & x) = 126 ElseIf Parameter("dn" & x) = "DN100 ⌀114" Then Parameter("DIA" & x) = 140 ElseIf Parameter("dn" & x) = "DN105 ⌀121" Then Parameter("DIA" & x) = 148 ElseIf Parameter("dn" & x) = "DN125 ⌀139" Then Parameter("DIA" & x) = 173 ElseIf Parameter("dn" & x) = "DN145 ⌀152" Then Parameter("DIA" & x) = 190 ElseIf Parameter("dn" & x) = "DN150 ⌀168" Then Parameter("DIA" & x) = 207 ElseIf Parameter("dn" & x) = "DN200 ⌀219" Then Parameter("DIA" & x) = 255 End If Next
