iLogic Rule - Current triangular notches of fold lines for flat patterns, need rectangular notches now.
MattyB92
MattyB92
Below is the current iLogic rule I am using, I have tried using ChatGPT to just modify the triangular notching to use either square or rectangular notching to no avail.
All iterations from ChatGPT have resulted in error after erro after running the rule so I am hoping someone may be able to point me in the right direction of how to excute it?
Sub Main
	'[ edit these variables as needed
	sSketchName = "Flat Pattern Notch Sketch"
	sCutName = "Fold Notches"
	'  a reference to the active document.
	Dim oPartDoc As PartDocument
	oPartDoc = ThisApplication.ActiveDocument
	'verify document type is sheet metal
	If oPartDoc.ComponentDefinition.Type <> 150995200 Then
		MessageBox.Show("File is not a sheet metal part.", "iLogic")
		Exit Sub
	End If
	Dim oCompDef As SheetMetalComponentDefinition
	oCompDef = oPartDoc.ComponentDefinition
	' Check to make sure a flat pattern is open.
	If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
		Try
			If oCompDef.HasFlatPattern = False Then
				oCompDef.Unfold
			Else
				oCompDef.FlatPattern.Edit
			End If
		Catch
			MessageBox.Show("Error editting the flat pattern.", "iLogic")
		End Try
	End If
	'  a reference to the active flat pattern.
	Dim oFlatPattern As FlatPattern
	oFlatPattern = ThisApplication.ActiveEditObject
	'clean up existing holes
	Dim oCut As ExtrudeFeature
	For Each oCut In oFlatPattern.Features.ExtrudeFeatures
		oCut.Delete
	Next
	Dim oFace As Face
	oFace = oFlatPattern.TopFace
	Dim oSketch As PlanarSketch
	'clean up existing sketch
	For Each oSketch In oFlatPattern.Sketches
		If oSketch.Name = sSketchName Then
			oSketch.Delete
		End If
	Next
	' Create a new sketch.
	' the Second argument specifies To include/Not include
	' the edges of the face in the sketch.
	oSketch = oFlatPattern.Sketches.Add(oFace, False)
	' Change the name.
	Dim oEdges As Edges
	' Create a new object collection for the hole center points.
	oHoleCenters = ThisApplication.TransientObjects.CreateObjectCollection
	' Get all Bend UP edges
	'where true = top face
	oEdges = _
	oFlatPattern.GetEdgesOfType( _
	FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True)
	'process the Bend Edges
	Call CreateSketch(oSketch, oEdges)
	' Get all Bend Down edges
	oEdges = _
	FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True)
	Dim oProfile As Profile
	oProfile = oSketch.Profiles.AddForSolid
	' Create an extrusion
	Dim oExtrude As ExtrudeFeature
	oExtrude = oFlatPattern.Features.ExtrudeFeatures.AddByThroughAllExtent(oProfile, kSymmetricExtentDirection, kCutOperation)
	oExtrude.Name = sCutName
	'oCompDef.FlatPattern.ExitEdit
	'	oPartDoc.Save
End Sub
Sub CreateSketch (oSketch As PlanarSketch, oEdges As Edges)
	Dim SketchFace As Face = TryCast(oSketch.PlanarEntity, Face)
	If SketchFace Is Nothing Then MessageBox.Show("Sketch Not created on face.") : Exit Sub
	Dim oUOM As UnitsOfMeasure
	oUOM = ThisDoc.Document.UnitsOfMeasure
	oLenUnits = oUOM.GetStringFromType(UnitsTypeEnum.kDefaultDisplayLengthUnits)
	oInvUnits = UnitsTypeEnum.kCentimeterLengthUnits
	oInvUnitString = oUOM.GetStringFromType(oInvUnits)
	oConversion = oUOM.ConvertUnits(1, oUOM.LengthUnits, oInvUnits)
	'Dim oBotDia As Double = .144 * oConversion
	'Dim oBotDia As Double = 0.425 * oConversion
	'Dim oBotDia As Double = 0.15 * oConversion
	Dim oBotDia As Double = 0.4 * oConversion
	For Each oEdge In oEdges
		'create line
		Dim skLine As SketchLine = oSketch.AddByProjectingEntity(oEdge)
		Call AddTriangleToLinePoint(SketchFace, oBotDia, skLine, "Start")
		Call AddTriangleToLinePoint(SketchFace, oBotDia, skLine, "End")
	Next
End Sub
Sub AddTriangleToLinePoint(TestFace As Face, CircleDiameter As Double, skLine As SketchLine, PointSelection As String)
	Dim TargetPoint As SketchPoint
	Dim TempPoint As SketchPoint
	Select Case PointSelection
	Case "Start"
		TargetPoint = skLine.StartSketchPoint
		TempPoint = skLine.EndSketchPoint
	Case "End"
		TargetPoint = skLine.EndSketchPoint
		TempPoint = skLine.StartSketchPoint
	Case Else
		MessageBox.Show("Can only add triangle to ""Start"" or ""End"" point of SketchLine")
		Exit Sub
	End Select
	Dim oSketch As PlanarSketch = skLine.Parent
	Dim oPolygon As SketchEntitiesEnumerator = oSketch.SketchLines.AddAsPolygon(3, TargetPoint.Geometry, TempPoint.Geometry, True)
	Dim oCircle As SketchCircle = oSketch.SketchCircles.AddByCenterRadius(TargetPoint.Geometry, CircleDiameter)
	oCircle.Construction = True
	oSketch.DimensionConstraints.AddDiameter(oCircle, TargetPoint.Geometry)
	oSketch.GeometricConstraints.AddCoincident(TargetPoint, oCircle.CenterSketchPoint)
	'Constrain Circle tangent to Lines of Polygon
	oSketch.GeometricConstraints.AddTangent(oPolygon.Item(1), oCircle)
	oSketch.GeometricConstraints.AddTangent(oPolygon.Item(2), oCircle)
	oSketch.GeometricConstraints.AddTangent(oPolygon.Item(3), oCircle)
	'Constrian polygon to line
	Dim coincidentPoint As SketchPoint = oPolygon.Item(1).StartSketchPoint
	oSketch.GeometricConstraints.AddCoincident(skLine, coincidentPoint)
	'Adjust coincident point if not on face
	Dim TestPoint As Point = TestFace.GetClosestPointTo(coincidentPoint.Geometry3d)
	Dim AdjustmentVector As Vector2d = Nothing
	If Round(TestPoint.DistanceTo(coincidentPoint.Geometry3d), 9) <> 0
		AdjustmentVector = coincidentPoint.Geometry.VectorTo(oCircle.CenterSketchPoint.Geometry)
		AdjustmentVector.ScaleBy(2)
		coincidentPoint.MoveBy(AdjustmentVector)
	End If
End Sub
jnowel
I just made the rule draw a square instead of the triangle. and have the first line of the square perpendicular to the bend line.
Sub Main
		Exit Sub
	End If
		Try
				oCompDef.Unfold
			Else
			End If
		Catch
		End Try
	End If
		oCut.Delete
	Next
	Dim oFace As Face
			oSketch.Delete
		End If
	Next
	' Change the name.
	Dim oEdges As Edges
	oEdges = _
	oEdges = _
	'	oPartDoc.Save
End Sub
		'create line
'		Call AddTriangleToLinePoint(SketchFace, oBotDia, skLine, "Start")
'		Call AddTriangleToLinePoint(SketchFace, oBotDia, skLine, "End")
		Call AddSquareToLinePoint(SketchFace, oBotDia, skLine, "Start")
		Call AddSquareToLinePoint(SketchFace, oBotDia, skLine, "End")
	Next
End Sub
	Case "Start"
	Case "End"
	Case Else
		Exit Sub
	End Select
	End If
End Sub
Sub AddSquareToLinePoint(TestFace As Face, CircleDiameter As Double, skLine As SketchLine, PointSelection As String)
	Case "Start"
	Case "End"
	Case Else
		MessageBox.Show("Can only add square to ""Start"" or ""End"" point of SketchLine")
		Exit Sub
	End Select
	Dim oPolygon As SketchEntitiesEnumerator = oSketch.SketchLines.AddAsPolygon()
	oSketch.GeometricConstraints.AddPerpendicular(oPolygon.Item(1),skLine)
'	'Constrian polygon to line
'	Dim coincidentPoint As SketchPoint = oPolygon.Item(1).StartSketchPoint
'	oSketch.GeometricConstraints.AddCoincident(skLine, coincidentPoint)
'	'Adjust coincident point if not on face
'	Dim TestPoint As Point = TestFace.GetClosestPointTo(coincidentPoint.Geometry3d)
'	Dim AdjustmentVector As Vector2d = Nothing
'	If Round(TestPoint.DistanceTo(coincidentPoint.Geometry3d), 9) <> 0
'		AdjustmentVector = coincidentPoint.Geometry.VectorTo(oCircle.CenterSketchPoint.Geometry)
'		AdjustmentVector.ScaleBy(2)
'		coincidentPoint.MoveBy(AdjustmentVector)
'	End If
End Sub
