iLogic - Rename workpoints in patterns
r.claus
r.claus
I try to rename workpoints within a rectangular pattern (see picture). This pattern or collection is created with a another collection of workpoints.
My problem is that the code only change the names of the first workpoints in each element.
Is there a way to change all the names?
'Set the document
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
'Set the component definition
Dim oCompDef As PartComponentDefinition
oCompDef = oDoc.ComponentDefinition
'Set the circular pattern features collection
Dim oCircularPatternFeature As CircularPatternFeature
oCircularPatternFeature = oCompDef.Features.CircularPatternFeatures.Item("PointPattern")
 Dim oElement As FeaturePatternElement
 	For Each oElement In oCircularPatternFeature.PatternElements
		If oElement.Index = 1 Then
			'do nothing
		Else
			Dim oworkpoint As WorkPoint
			oworkpoint = oElement.ResultFeatures.Item(1)
			oworkpoint.Name = "TestPoint" & oElement.Index
	Next
ThisDoc.Document.Update
TomaszDąbrowski
I am not sure if I understand your idea, but please try if this code works.
'Set the document
Dim i As Integer
Dim k As Integer = 1
			'do nothing
		Else
				For i = 1 To oElement.ResultFeatures.count
			oworkpoint = oElement.ResultFeatures.Item(i)
			oworkpoint.Name = "TestPoint" & k
			k=k+1
				Next
	Next
r.claus
thanks for your fast help.
I had forgotten that I have rectangular patterns but I just change this and your code works.
Thank you very much 🙂
