Ilogic rename parameter dialog box
Hello Im new in Ilogic and was wondering if there is a way to rename a new dimension parameter in sketch with a dialog box directly not having to go to Functions or diemnsion properties.
thnks in advance
MegaJerk
Simply type in a new name and the number that you'd like it to equal like this :
"NewParameterName = 100"
It will change the d# to NewParameterName, and set the value to 100 (of whatever unit you are using) .
Picture example below!
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
thanks this is very handy
