iLogic: Quantity in parts drawing from Assembly BOM
Message 1 of 14
Hi to all. I have a question.
Each of our part drawings has quantity based on the assembly BOM. We export the BOM to excel then manually type the quantity in the drawing.
So I wonder, is there any way thru iLogic that we can get the quantity from BOM and set it as custom iproperty in the drawing?
Maybe we can turn the partslist into an assembly iproperties, then read that from the part drawing.
Replies (13)
Message 2 of 14
WCrihfield
Yes. All standard BOM quantities should be available to view within the Parts List in the drawing.  There are several Quantities involved with BOM's though.
  • BASE QTY (& BASE UNIT)
  • ITEM QTY
  • UNIT QTY
Within the Parts List dialog, click on the "Column Chooser" button (top left).  With "All Properties" showing in the drop-down list under "Select available properties from:", scroll through the list of available properties, select it, then click the [Add->] button to add it to your existing Parts List columns.  Then arrange them in the order you want them on the right.  Then click [OK] button to finish.
Is this what you wanted, or is the Quantity you have in mind within a Custom iProperty, or do you need to pull it in from Excel?
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 14
I had placed the partslist of the drawing then removed the other column except quantity. Then I applied filter by item number. But these filters are very limited. The problem was when the sorting change and renumbering occured.
The filter by item number would stay, but the part number and quantity could be different.1.jpg
Message 4 of 14
WCrihfield
Perhaps using the "Assembly View Representation" type filter would work better for you?  That's what I often use.  You don't necessarily need to have your Parts List tied to a specific drawing view to use this.  It just goes how the DesignViewRepresentation (that you choose after setting this type of filter) is set-up.  You can easily have several DVR's in your Assembly.  (DVR's deal with component visibility is set to On/Off, not whether components are suppressed or not.)  Then there is also an additional setting (check box) to "Limit QTY to visible components only".
Wesley Crihfield
Message 5 of 14
WCrihfield
@Anonymous  And yes it is fairly easy to send data back and forth between model file and drawing file, especially Custom iProperties, if needed.
Wesley Crihfield
Message 6 of 14
My understanding is that you have an assembly and you want to create drawings for each individual part?
If so below is code that I frankensteined together and modified to fit my purposes, I believe you will be able to use it as well.  If you have any questions about it feel free to ask.
Sub Main()
'If the assembly is declared as a Component assignment of Item # and QTY. is unnecessary
If iProperties.Value("Summary", "Subject") = "Component" Then
Else
'Reference Assembly Document
Dim oAssemblyDocument As AssemblyDocument
oAssemblyDocument = ThisDoc.Document
'Reference each instance of a model in the assembly
Dim oAssemblyComponentDefinition As AssemblyComponentDefinition
oAssemblyComponentDefinition = oAssemblyDocument.ComponentDefinition
'Reference the Bill Of Materials
Dim oBOM As BOM
oBOM = oAssemblyComponentDefinition.BOM
'Call for Structured View
oBOM.StructuredViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews(2) 'Structured view
'Only change the Top Level of the Model Tree models
'models within sub-assemblies are ignored.
oBOM.StructuredViewFirstLevelOnly = True
oBOM.StructuredViewDelimiter = "."
'Call sub-programs
Call RecursiveCheckAndSetProps(oBOMView.BOMRows)
Call UpdateParts()
End Sub
Sub RecursiveCheckAndSetProps(ByVal oRowsElements As BOMRowsEnumerator)
'Loop for each unique model in the assembly
For Each oBOMRow As BOMRow In oRowsElements
		'Reference property of models within assembly
		Dim oComponentDefinition As ComponentDefinition
		oComponentDefinition = oBOMRow.ComponentDefinitions.Item(1)
		'Reference variables to BOM Item # and QTY.
		Dim oBOMItemNumber As String
		Dim oBOMItemQuantity As String
		oBOMItemQuantity = oBOMRow.ItemQuantity() 'this is item quantity in the BOM
		oBOMItemNumber = oBOMRow.ItemNumber() 'this is item number in the BOM
	For i = 1 To oBOMRow.ComponentDefinitions.Count
		Dim oComponentDefinitionPropertySet As PropertySet
		oComponentDefinitionPropertySet = oBOMRow.ComponentDefinitions(i).Document.PropertySets.Item(4)
		oComponentDefinition = oBOMRow.ComponentDefinitions.Item(i)
		oComponentDefinitionPropertySet = oComponentDefinition.Document.PropertySets.Item("Inventor User Defined Properties")
		'Check to see if model has had BOM Item # set, if so skip editing model iProperties
		Try
			prop = oComponentDefinitionPropertySet.Item("BOM Number")
		Catch
			'Add BOM Item # and QTY. as Custom iProperties
			Try
				oComponentDefinitionPropertySet.Add(oBOMItemNumber, "BOM Number")
				oComponentDefinitionPropertySet.Add(oBOMItemQuantity, "BOM QTY")
			Catch
				oComponentDefinitionPropertySet.Item("BOM Number").Value = oBOMItemNumber
				oComponentDefinitionPropertySet.Item("BOM QTY").Value = oBOMItemQuantity
			End Try
		End Try
Logger.Info(oBOMRow.ComponentDefinitions(i).Document.DisplayName & " - " & oBOMItemNumber)
	Next
Next
End Sub
Sub UpdateParts()
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim aDoc As DocumentsEnumerator = oDoc.AllReferencedDocuments
	Dim iDoc As Document
For Each iDoc In aDoc
    'Here we set iProperties in each of the parts in assembly
	Dim sTS As String = iDoc.FullFileName
	Dim FNamePos As Long = InStrRev(sTS, "\", - 1)
	Dim docFName As String = Mid(sTS, FNamePos + 1, Len(sTS) -FNamePos)
		'Add BOM Item # & QTY. to iProperty Fields Company and Manager respectively
		If iProperties.Value(docFName, "Custom", "BOM Number") = "" Then
		Else
			iProperties.Value(docFName, "Summary", "Manager") = iProperties.Value(docFName, "Custom", "BOM QTY")
			iProperties.Value(docFName, "Summary", "Company") = iProperties.Value(docFName, "Custom", "BOM Number")
Next
End Sub
Message 7 of 14
Thank you @Anonymous  for your time, it works fine and I also learning from these codes.
The disadvantage here (the way we are st-up)  is that it affect the standard parts which is also used by the other team. Because we are using cloud, everytime the part is updated, it sync (takes 15 - 30 mins).
There are two other option Im thinking whic will not affect our standard part.
1.) To write the custom iproperties in the assembly itself. Then in the drawing, another iLogic to get the iproperties from the assembly.
iProperties.Value((DrawingFileName = PartName), "Custom", "Qty") = iProperties.Value(AssemblyName, "Custom", "QtyPartNumber")
 2.) (just lost my idea as we always have power outage today...wil update this post)
Message 8 of 14
Yes @WCrihfield  filter by view representation works.
Im thinking of ilogic to create view representation of each part in the assembly. And another ilogic in drawing (template)  sheet to set the partslist filter. The part filename, part number, view representation name should be the same.
Message 9 of 14
drslayer35
I have been trying to do this for a while now and found you code works well.
I have tried to modify it to run on the parts only BOM and not had any success. I have several parts used in different assemblies and have been trying to get the BOM qty info into each part. Are you able to run code similar to this on each part in the Parts Only view?
Jeff
Jeff
Windows 7 64
Product Design Suite Premium 2014
AMD 8350 32 GB
Dual AMD FirePro V4900
Message 10 of 14
If you can post the code that you are trying I or someone else may be able to help.  Right now the code modifications that I found are replacing the following:
with
'Call for Parts Only View
oBOM.PartsOnlyViewEnabled = True
oBOMView = oBOM.BOMViews(3) 'Parts Only view
The intent for this code was that everything in the "first level" of the assembly browser would be included, if you only need to have a standard parts list without specifying subassemblies and their components then I would recommend breaking down the subassemblies by 'Promoting' the components to the first level.
Message 11 of 14
drslayer35
That was exactly what I was trying to do.
Thank you so much. I've been working on this for a while now.
Kudos to you.
Jeff
Windows 7 64
AMD 8350 32 GB
Message 12 of 14
alessandro.pruscino
I know I'm resurrecting a 3-4 year old thread, but I absolutely love this Ilogic code, takes out my human error for counting the amount of components to have made.
Message 13 of 14
uwegross
Community Visitor
Community Visitor
When I run the rule I get the below mentioned error
Error on line 96 in rule: qty updated rule, in document: Single Bay Vaccum Ver 2.iam
iProperties: Cannot find a property named "BOM Number".
Message 14 of 14
WCrihfield
Hi @uwegross.  If you are referring to the code posted within Message 6 above, then that is a 'custom' iProperty, not a standard one.  Custom iProperties do not exist until you create them.  Sometimes we may have created some custom iProperties within a template document, then created new documents from that template, and the new documents will have them in it.  Also, if you have marked any of your Parameters for Export within the Parameters dialog, that will automatically create custom iProperties for those Parameters with the same names and values as those parameters.  This is why that code example contains some Try...Catch...End Try statements, because if it can not find the custom iProperty already existing, then it is supposed to create the custom iProperty, then set its value.  However, that is not always possible either, if that Document is ReadOnly for some reason, such as content center stuff, or files located in Library locations, and other similar situations.  When the document is ReadOnly, it may still throw an error message, because what was specified on both the Try, and the Catch side of the statement both failed.
Wesley Crihfield
