Change dimension style on all sheets
kresh.bell
kresh.bell
is it possible to make a logic that will select and change dimension style on all sheets, eg. I want to change the dimension style on all sheets, eg on 50 of them
WCrihfield
Would something like this work for you?
You would of course, have to set the style you want in a slightly different way.
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oDStyle As DimensionStyle = oDDoc.StylesManager.DimensionStyles.Item(1)
Dim oSheet As Sheet
Dim oDims As DrawingDimensions
For Each oSheet In oDDoc.Sheets
	oDims = oSheet.DrawingDimensions
	For Each oGDim As GeneralDimension In oDims.GeneralDimensions
		oGDim.Style = oDStyle
	Next
	For Each oODim As OrdinateDimension In oDims.OrdinateDimensions
		oODim.Style = oDStyle
	Next
	For Each oODimSet As OrdinateDimensionSet In oDims.OrdinateDimensionSets
		oODimSet.Style = oDStyle
	Next
	For Each oCHDimSet As ChainDimensionSet In oDims.ChainDimensionSets
		oCHDimSet.Style = oDStyle
	Next
	For Each oBLDimSet As BaselineDimensionSet In oDims.BaselineDimensionSets
		oBLDimSet.Style = oDStyle
	Next
Next
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
@kresh.bell
You could replace the line
with something like this
For Each oDimStyle As DimensionStyle In oDDoc.StylesManager.DimensionStyles
	If oDimStyle.Name.Contains("Something") Then
		oDStyle = oDimStyle
Next
and replace "Something" with the name of the dimension style you want.
Wesley Crihfield
kresh.bell
I'm doing something wrong, I'm getting an error, the dimension style is called PRL_Style
WCrihfield
I see it.  Within the loop searching for the dimension style by that name, you're using
Contains.RPL_Style Then
It should be
Contains("RPL_Style") Then
Like this:
	If oDimStyle.Name.Contains("RPL_Style") Then
		oDStyle = oDimStyle
Next
Dim oSheet As Sheet
	Next
	Next
	Next
	Next
	Next
Next
Wesley Crihfield
kresh.bell
works great, thanks !!!
