iLogic - Pull Material from specific part to assembly
frederik_vollbrecht
frederik_vollbrecht
I just got some time to write a dirty iLogic to pull the Material from a part to the assembly.
I wrote this, because most of the time when designing sheet metal assemblys with pressed bolts etc. the assembly and the main sheet metal part get the same name.
frederik_vollbrecht
' Pull Material from sheet metal part to sheet metal assembly
' Copyright Frederik Vollbrecht 2020
' V 1.0
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
        oAsmDoc = ThisApplication.ActiveDocument
    ' Get the definition of the assembly.
    Dim oAsmDef As AssemblyComponentDefinition
        oAsmDef = oAsmDoc.ComponentDefinition
	' Some kind of error handling
Try
    ' Get the document to find occurrences for. It will be asumed that both, part
    ' and assembly, have the same filename
    Dim oDoc As Document
        oDoc = ThisApplication.Documents.ItemByName(  ThisDoc.PathAndFileName(False) & ".ipt")
    ' Get the occurrences that represent this document.
    Dim oOccs As ComponentOccurrencesEnumerator
        oOccs = oAsmDef.Occurrences.AllReferencedOccurrences(oDoc)
    ' Set definition of the Material var
        oMat = oDoc.ComponentDefinition.Material.Name
	' Create iProperty in the assembly containing the part material
		iProperties.Value("Custom", "Material") = oMat
Catch
		MessageBox.Show("Baugruppe enthält keine Blechkonstruktion", "Fehler")
End Try
