iLogic program to Save as PDF without line weights
Hello All,
I have an iLogic program that saves part drawings as a PDF in a specific location. I needed to edit the program to save the PDF documents without object line weights, rather than having to manually export as a pdf and select that from the options menu. I was reading through the iLogic API and found the recommend code, but I can't seem to get it to work (regardless of whether I assign the number "0" or "1" to the "oOptions.Value("Remove_Line_Weights")" line of code).
Does anyone know how to make this work?
I've included the code here:
Thanks!
SyntaxEditor Code Snippet
' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        oOptions.Value("Remove_Line_Weights") = 0
        oOptions.Value("Vector_Resolution") = 400
        'oOptions.Value("Sheet_Range") = kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    End If
EPN = iProperties.Value("Project", "Part Number")
If(Not System.IO.Directory.Exists("G:\PUBLIC\EPNFOLDERS\" & EPN)) Then
    System.IO.Directory.CreateDirectory("G:\PUBLIC\EPNFOLDERS\" & EPN)
End If
'Saves the PDF in the desired location
ThisDoc.Document.SaveAs("G:\PUBLIC\EPNFOLDERS\" & EPN & "\" & EPN & " PRINT.pdf" , True)
rhasell
Hi
I think the problem is in the last line, you don't actually specify the options in the save.
Here is a snippet of my code.
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Vector_Resolution") = 4800
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
End If
'---End PDF settings
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
		Dim strIniFile As String
        strIniFile = "C:\Data\2016-acadexport-[jun16]-2.ini"
        oOptions.Value("Export_Acad_IniFile") = strIniFile
	oFolder ="C:\DATA\1 EXPORT"
	oDataMedium.FileName =oFolder + "\" + oFileName & "[" & oRevNum & "]" & ".pdf"
If System.IO.File.Exists(oDataMedium.FileName) Then
	 oChoice=MessageBox.Show(oDataMediumPDF.FileName & " Already Exists - Overwrite?", "Title", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
		If oChoice=7
			Return
			Else
		End If
End If
'''--- Publish document.
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
MessageBox.Show("Done!", "Title")
Reg
2026.1
rhasell
Hi
I forgot to remove some of the lines from the AutoCAD export, just ignore them.
Also, I don't remove line weights, that is why mine is still at zero, but if you change it to a "1" it will work.
Reg
2026.1
Ah ok, I adjusted how the file is saved so that I can include the options. Thanks for pointing that out, works correctly now!
-Nick
