Ilogic program to override the value of Balloon.
naveedmX3N25
Message 1 of 10
naveedmX3N25
What is wrong with my code to change the override value of my balloon?
' iLogic rule to change the balloon value by asking the user to enter a value
Dim valueEntered As String
' Prompt the user to enter a value
valueEntered = InputBox("Enter the value for the balloon:", "Balloon Value")
' Check if the user entered a value
If valueEntered <> "" Then
    ' Update the balloon value with the user-entered value
	 ThisDrawing.Sheet.Balloons.ManagedItem.Name.Equals = valueEntered
Else
    MsgBox("No value entered. Balloon value remains unchanged.")
End If
Thanks in advance.
Accepted solutions (3)
Replies (9)
Message 2 of 10
WCrihfield
Hi @naveedmX3N25.  In that short code there are multiple issues.  First, it is not specifying which specific sheet to access.  Second, it is not specifying which Balloon to access.  Third, it is not accessing the correct property of that Balloon.  Balloons do not have names, but they do have a BalloonValueSets collection, because we can chain multiple Balloons together.  Most of the time there is just one item in that collection though (a BalloonValueSet type object).  Then you still have to set its 'override' value.
Below is an example of one possible different variation of your code that might possibly work, but no guarantees.
It is working with the 'active' sheet, then the first Balloon on that sheet (by index number, not by name), then accessing its first BalloonValueSet, then setting its override value.
	 ThisDrawing.ActiveSheet.Balloons.NativeEntity.Item(1).BalloonValueSets.Item(1).OverrideValue = valueEntered
Else
End If
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 10
naveedmX3N25
Thank you for correcting my code.
It is possible to make it some a way that it only overrides the balloon that I have selected?
Message 4 of 10
WCrihfield
Hi @naveedmX3N25.  Sure.  Here is another iLogic code example that will allow you to either pre-select (before you run the rule), or 'pick' one (while the rule is running), then do essentially the same thing.
Dim oDDoc As DrawingDocument = ThisDrawing.Document
'Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
'Dim oBalloons As Inventor.Balloons = oSheet.Balloons
'If oBalloons.Count = 0 Then Return 'exit rule - no Balloons on the active sheet
Dim oSS As SelectSet = oDDoc.SelectSet
Dim oBalloon As Inventor.Balloon = Nothing
If oSS.Count > 0 Then
	If TypeOf oSS.Item(1) Is Inventor.Balloon Then
		oBalloon = oSS.Item(1)
	End If
Else
	oBalloon = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingBalloonFilter, "Select A Balloon")
End If
If oBalloon Is Nothing Then
	MsgBox("No Balloon pre-selected or picked.  Exiting rule.")
	Return 'exit rule because no Balloon was selected
End If
'get its first BalloonValueSet
Dim oBVS As BalloonValueSet = oBalloon.BalloonValueSets.Item(1)
'prompt user to enter new value for the Balloon, showing its current value as default value
Dim valueEntered As String = InputBox("Enter the value for the balloon.", "Balloon Value", oBVS.ItemNumber)
	 oBVS.OverrideValue = valueEntered
Else
End If
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
Message 5 of 10
J-Camper
This will have the user select a balloon to change and then be prompted for the input value:
Dim dDoc As DrawingDocument = TryCast(ThisApplication.ActiveDocument, DrawingDocument)
If IsNothing(dDoc) Then Logger.Debug("Not Run In Drawing Document") : Exit Sub
Dim PickBalloon As Balloon = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingBalloonFilter, "Select a Balloon")
While PickBalloon IsNot Nothing
	Dim valueEntered As String = InputBox("Enter the value for the balloon:", "Balloon Value", PickBalloon.BalloonValueSets.Item(1).OverrideValue)
	If valueEntered Is String.Empty Then MsgBox("No value entered. Balloon value remains unchanged.") : Exit While
	PickBalloon.BalloonValueSets.Item(1).OverrideValue = valueEntered
	PickBalloon = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingBalloonFilter, "Select a Balloon")
End While
Is this what you want?
Edit: Didn't notice before replying myself
Message 6 of 10
naveedmX3N25
Thanks for this Code.
I am trying to figure out on how make this so that I can select multiple ones and make all of them the same override value.
Currently when I try it doesn't.
Message 7 of 10
J-Camper
@naveedmX3N25,
This will let you pre-select then change all selected to the same entered value OR let you enter a value then select balloons to change one-by-one:
Dim valueEntered As String = InputBox("Enter the value for the balloon(s):", "Balloon Value")
If valueEntered Is String.Empty Then MsgBox("No value entered") : Exit Sub
If dDoc.SelectSet.OfType(Of Balloon).Count < 1
	End While
Else
	Dim SelectedBallons As IEnumerable = dDoc.SelectSet.OfType(Of Balloon)
	For Each b As Balloon In SelectedBallons
		b.BalloonValueSets.Item(1).OverrideValue = valueEntered
	Next
End If
 It will create a new undo item for each balloon changed.
This version will batch all the changes into a single transaction envelope:
If valueEntered Is String.Empty Then MsgBox("No value entered.") : Exit Sub
Dim transMan As TransactionManager = ThisApplication.TransactionManager
Dim oTrans As Transaction = transMan.StartTransaction(dDoc, "Batch Balloon Overrides")
On Error GoTo Errrr
	End While
Else
	Next
End If
oTrans.End 'Typical transaction end
Exit Sub 'Finish the Sub routine before Error Handling code
Errrr :
MsgBox("Aborted: " & transMan.CurrentTransaction.DisplayName) : transMan.CurrentTransaction.Abort
Exit Sub
Let me know if you have any questions
**Edit: Made corrections to code based on my comment in message 9
Message 8 of 10
naveedmX3N25
Thank you, great knowledge!!
Message 9 of 10
J-Camper
@naveedmX3N25,
I realized something after posting.  I was using the .Cast(Of Object) on the selectset, but that will throw an error if more than just balloons are selected.  Please change all ".Cast" To ".OfType" [Lines 7 & 15 of first block | Lines 12 & 21 of second block]
I will also post the second block as a txt file, with those 2 lines corrected.
Message 10 of 10
naveedmX3N25
Thank you worked perfectly!
