Ilogic Print Rule
Ilogic Print Rule
Ilogic Print Rule
Hi all
i've just started out with Ilogic programing and i have run into my first hurdle
i'm trying to write a rule to print .idw's or .dwg's with the correct settings
i want the Drawing sheet size to be the paper size it prints in. but no matter wich printer i choose or what i change about the Rule it eihter gives an error or prints on the default paper size of the printer
this is what i have so far (no errors when i run it)
Dim oDrgDoc As DrawingDocument
oDrgDoc = ThisApplication.ActiveDocument
' Set reference to drawing print manager' DrawingPrintManager has more options than PrintManager' as it's specific to drawing document
Dim oDrgPrintMgr As DrawingPrintManager
oDrgPrintMgr = oDrgDoc.PrintManager
' Set the printer name' comment this line to use default printer or assign another one'oDrgPrintMgr.Printer = "\\S-BE-JTEC-DATA\P-BE-JTEC-020"'oDrgPrintMgr.Printer = "Bullzip PDF Printer"
oDrgPrintMgr.Printer = "\\S-BE-JTEC-DATA\P-BE-JTEC-006"
'Set the paper size , scale and orientation
oDrgPrintMgr.Scalemode = kCustomScale
oDrgPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
oDrgPrintMgr.PaperSize = kPaperSizeA3
'oDrgPrintMgr.PaperSize = kcustomsize'oDrgPrintMgr.PaperHeight = 16.54'oDrgPrintMgr.PaperWidth = 23.39
oDrgPrintMgr.PrintRange = kPrintCurrentSheet
oDrgPrintMgr.Orientation = kLandscapeOrientation
oDrgPrintMgr.ColorMode = kPrintColorPalette
'oDrgPrintMgr.ColorMode = kPrintGrayScale'oDrgPrintMgr.AllColorsAsBlack = True
oDrgPrintMgr.SubmitPrint
one though i had was that the plotter uses the name "ISO A2" for an A2 page and that there is the problem but even the PDF printer gets the wrong format
Most of all i would like to have one button that prints the active sheet in the active sheets size with the correct orientation and the correct scale
Anyone have a good code to solve this enigma
thanks
I think your problem is that you need to use PrintSizeEnum to set the correct paper size.
See my code below that works for me
SyntaxEditor Code Snippet
oDrgPrintMgr.Printer = "\\PRINTSERV\Upstairs Copier"
oDrgPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeA3
oDrgPrintMgr.AllColorsAsBlack = False
Hi
Thanks for the Reply
I added that and it printed perfectly on one printer but the plotter still didn't change it's paper size
And is there a way to make the sheet size the actual paper size during printing/plotting?
        'oDrgPrintMgr.Printer = "\\S-BE-JTEC-DATA\P-BE-JTEC-006"
        oDrgPrintMgr.ScaleMode = kPrintBestFitScale
        oDrgPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeA2
        oDrgPrintMgr.PrintRange = kPrintAllSheets
 thanks
Instead of kPaperSizeA2 try using the value
oDrgPrintMgr.PaperSize = PaperSizeEnum.14339
For a custom size you can try kPaperSizeCustom (or the value 14355) and then set the size
oPrintMgr.PaperHeight = 15
oPrintMgr.PaperWidth = 10
I've tried both those approaches and i keep comming up with the same result
Could it have to do with the fact that it has to change the paper setings on the printer and not in the printer manager?
All other criteria can be changed in the Printer manager except the paper size that is on the Properties of the printer itself
is there a way to get there?
This is still bug in Inventor API!
Now I have to use hardcoded PaperSizeEnum values when printing to laser!
Hey come on Autodesk! Please fix it!
Related post:
http://inventorhub.autodesk.com/discussions/threads/120/post/2539524
