Custom iProp used in Linked Parameter using iLogic
cadman777
Advisor Advisor
cadman777
Does anybody have any code, or can you offer a suggested work-flow for the following task which I can't figure out even how to start:
I want to push a Custom iProp from an ipt into a Linked Parameter in another ipt.
Thanx
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
EelcoWiggers
hi Chris,
Take a look in the programming help and search for "DerivedParameterTable". There is a example that demostrates the selective linking of parameters from another Inventor file.
I see no possibility to directly link a iProperty into a linked parameter but maybe I am mistaken here.
Just thinking outlout here to help you get started, what is you purpose here, do you want have a linked parameter wich can be updated when the source parameter is changed? And what type of value you want to be linked into another file?
Eelco
cadman777
Eelco,
Thanx for helping me.
After re-reading my question, I see that it wasn't worded right.
After scrubbing a re-statement, I'm finding this question too complicated to re-state.
Thanx againfor your input.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
VdVeek
When i read your your sentence: I want to push a Custom iProp from an ipt into a Linked Parameter in another ipt. This code comes to mind:
Parameter("Part1:1", "d0") = iProperties.Value("Custom", "PropertyName")
 The value of the Custom iproperty "PropertyName" from the active part/assy is send to the Parameter "d0" in Part/Assy:"Part1".
Otherwise try to write down the steps when performing the workflow manualy for a better understanding.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
