iLogic Placed Dimension Failing at AddLinear Step
mikek3QMMC
mikek3QMMC
I am extremely new to object oriented programming and iLogic/VBA in general, but so far I've been able to overcome most of the issues I've come across.  Currently, I'm roadblocked at an error I cannot seem to shake.   Under the cases, I am able to complete cases 1 and 2, then it fails on case 3 and 4.  The rule I'm working on is Straight_Pull_Bar_Dim and I'm working on the Interior View.  I am dimensioning from the bottom of one assembly to a straight inset line on the bottom of a rounded piece.  I originally tried dimensioning to the rounded piece directly, but I kept getting the same error, and even though the geometry is the same for the exterior view, I don't have any errors when that section runs.  All attributes are named at the master assembly level.  Is there some kind of limitation to a general linear dimension?  From everything I understand, this should be working just fine.  I can dimension the each intent as a single dimension (ie my intent 1 will dimension by itself at the oPT2 and my intent 2 will dimension itself at oPT2) but intent1 and intent2 together fail.  It is failing at the oGeneralDims.AddLinear line inside of the while loop.
Error on line 154 in rule: Straight_Pull_Bar_Dim, in document: Sub Dwg MS Standard Stack V2.idw
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
'--- Initial Setup---
'Lazy variables to switch between locking levers, pull bars, and recessed pulls
Dim sHdwrName As String = "St"
Dim sHdwrTag As String = "Straight<br/>Pull Bar"
Dim dYVal As Double = (Parameter("Master Assembly 1.iam.Pull_Bar_Height")/Parameter("Master Assembly 1.iam.Unit_height"))
'Reference this document
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisDoc.Document
'Reference this drawing sheet
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'Determine if the sheet is an interior view or exterior view to set-up variable names later to correctly pull the right attribute face
Dim tViewName As String
If oSheet.Name = "Exterior View:2" Then
	tViewName = "Exterior"
Else
	tViewName = "Interior"
'References this drawing view
Dim oView As DrawingView
oView = ActiveSheet.View(tViewName+" View").View
'References the Drawing Model
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ActiveSheet.View(tViewName + " View").ModelDocument
'Setting up the variable names to interior and exterior views
Dim tPiece1 As String
Dim tPiece2 As String
'Declaring Variables to determine how many (if any) panels are on the right or left side
Dim iLPanels As Integer = Max(Parameter("Master Assembly 1.iam.Panels_L"), Parameter("Master Assembly 1.iam.Astragal_Panels_L"))
Dim iRPanels As Integer = Max(Parameter("Master Assembly 1.iam.Panels_R"), Parameter("Master Assembly 1.iam.Astragal_Panels_R"))
'declaring a string variable to append if the component is an astragal
Dim sLAst As String = ""
Dim sRAst As String = ""
'Setting the variables to "Ast" if the component is an astragal component
If Parameter("Master Assembly 1.iam.Astragal_Panels_L") > 0 Then
	sLAst = "Ast"
If Parameter("Master Assembly 1.iam.Astragal_Panels_R") > 0 Then
	sRAst = "Ast"
'Readys code for creation of general dimensions
Dim oGeneralDims As GeneralDimensions
oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions
'---Dimensions Prep---
'Variable declarations to be used later on
Dim oPt2 As Point2d
Dim aoEdge4 As Face
Dim aoEdge3 As Face
Dim aoDrawCurves4 As DrawingCurve
Dim aoDrawCurves3 As DrawingCurve
Dim oDim2 As GeneralDimension
Dim oDim2Att As AttributeSet
Dim iCounter As Integer = 1
Dim sHandle As String
Dim iXVal As Integer
Dim bHandlePresent As Boolean
Dim sInOut As String
'Setting variabel sIntOut, which is used for finding the correct parameter in the document
If tViewName = "Exterior" Then
	sInOut = "_OUT"
Else
	sInOut = "_IN"
While iCounter < 5
	Select iCounter
		Case 1
			sHandle = ("LSH" & sLAst & (Parameter("Master Assembly 1.iam.Panels_L") + Parameter("Master Assembly 1.iam.Astragal_Panels_L")) & "X")
			bHandlePresent = Parameter("Master Assembly 1.iam.LSH_" + sHdwrName + sInOut)
			'switches xval based on if it's interior or exterior since the view flips
				tPiece1 = ("BottomRailLSH" & sLAst & iLPanels & "X" & tViewName)
				iXVal = (oView.Left + 2.25)
			Else
				tPiece1 = ("BottomRailLSHC" & sLAst & iLPanels & "X" & tViewName)
				iXVal = (oView.Left + oView.Width - 2.25)
		Case 2
			sHandle = ("LSHC" & sLAst & (Parameter("Master Assembly 1.iam.Panels_L") + Parameter("Master Assembly 1.iam.Astragal_Panels_L")) & "X")
			bHandlePresent = Parameter("Master Assembly 1.iam.LSHC_" + sHdwrName + sInOut)
				iXVal = (oView.Left + oView.Width * (Parameter("Master Assembly 1.iam.Frame_Dbl_LS") / (Parameter("Master Assembly 1.iam.Frame_Dbl_LS") + Parameter("Master Assembly 1.iam.Frame_Dbl_RS"))) - 2.25)
			Else
				iXVal = (oView.Left + oView.Width * (Parameter("Master Assembly 1.iam.Frame_Dbl_LS") / (Parameter("Master Assembly 1.iam.Frame_Dbl_LS") + Parameter("Master Assembly 1.iam.Frame_Dbl_RS"))) + 2.25)
		Case 3
			sHandle = ("RSHC" & sRAst & (Parameter("Master Assembly 1.iam.Panels_R") + Parameter("Master Assembly 1.iam.Astragal_Panels_R")) & "X")
			bHandlePresent = Parameter("Master Assembly 1.iam.RSHC_" + sHdwrName + sInOut)
				tPiece1 = ("BottomRailRSH" & sRAst & iRPanels & "X" & tViewName)
			Else
				tPiece1 = ("BottomRailRSHC" & sRAst & iRPanels & "X" & tViewName)
				iXVal = (oView.Left + oView.Width * (Parameter("Master Assembly 1.iam.Frame_Dbl_LS") / (Parameter("Master Assembly 1.iam.Frame_Dbl_LS") + Parameter("Master Assembly 1.iam.Frame_Dbl_RS"))) -2.25)
		Case 4
			sHandle = ("RSH" & sRAst & (Parameter("Master Assembly 1.iam.Panels_R") + Parameter("Master Assembly 1.iam.Astragal_Panels_R")) & "X")
			bHandlePresent = Parameter("Master Assembly 1.iam.RSH_" + sHdwrName + sInOut)
			Else
	End Select
	If bHandlePresent = TRUE Then
		tPiece2 = (sHdwrName + sHandle + tViewName)
		'finds edges with particular attributes then takes the first instance
		oObjs = oAssyDoc.AttributeManager.FindObjects("Dim",tPiece1,"1")
		aoEdge4 = oObjs.Item(1)
		oObjs = oAssyDoc.AttributeManager.FindObjects("Dim",tPiece2,"1")
		aoEdge3 = oObjs.Item(1)
		'Find the drawing edge that represents the one with the attribute
		oDrawViewCurves = oView.DrawingCurves(aoEdge4)
		aoDrawCurves4 = oDrawViewCurves.Item(1)
		oDrawViewCurves = oView.DrawingCurves(aoEdge3)
		aoDrawCurves3 = oDrawViewCurves.Item(1)
		'Placement position of the dimension
		'oPt2 = ThisApplication.TransientGeometry.CreatePoint2d(x position, y position).
		'oView.Left starts you at the left of the view window, oView.Width  is the width  of the view
		'oView.Top  starts you at the top  of the view window, oView.Height is the height of the view
		oPt2 = ThisApplication.TransientGeometry.CreatePoint2d(iXVal, oView.Top - oView.Height * (1 - dYVal))
		'---Creating Dimensions---
		oDim2 = oGeneralDims.AddLinear(oPt2, oSheet.CreateGeometryIntent(aoDrawCurves3), oSheet.CreateGeometryIntent(aoDrawCurves4))
		oDim2.Text.FormattedText = (sHdwrTag & ":<br/> <DimensionValue/><br/>Case: " & iCounter)
		'Adds the tag "iLogic_Created" to the dimension so it can be removed by the delete dims rule.
		oDim2Att = oDim2.AttributeSets.Add("iLogic_Created")
	iCounter = iCounter + 1
End While
mikek3QMMC
Here is a severely more cut down variant of the code since most of this is set-up for deciding which lines to grab.  This is hardcoded for the variables, which still have the same issue.  Hopefully this is more digestible.
Dim oSheet As Sheet
oView = ActiveSheet.View("Interior View").View
oAssyDoc = ActiveSheet.View("Interior View").ModelDocument
While iCounter < 5
	Select iCounter
		Case 1
			sHandle = "LSH2X"
			bHandlePresent = True
			tPiece1 = "BottomRailLSHC2XInterior"
		Case 2
			sHandle = "LSHC2X"
		Case 3
			sHandle = "RSHCAst2X"
			tPiece1 = "BottomRailRSHCAst2XInterior"
		Case 4
			sHandle = "RSHAst2X"
	End Select
		tPiece2 = ("St" + sHandle + "Interior")
		oPt2 = ThisApplication.TransientGeometry.CreatePoint2d(iXVal, oView.Top-oView.Height/2)
		oDim2.Text.FormattedText = (iCounter & ":<br/> <DimensionValue/>")
End While
