Disabling "Save Copy As" Button - VBA
Tiffany_Hayden_
Tiffany_Hayden_
I was curious if anyone has run into the need to grey out the "Save Copy As" functionality under File?
I tried to run the same code that I'm using to disable other commands but it doesn't seem to disable the command. I'm wondering if I have to do something different since it's an embedded command? Any help would be appreciated.
Public Sub DisableAssemblySaveCopyAsCmd() '(oAssyDoc As AssemblyDocument)
    Dim oDrawDoc As DrawingDocument: Set oDrawDoc = ThisApplication.ActiveDocument
    ' DISABLES THE MIRROR COMMAND WITHIN A SPECIFIED ASSEMBLY DOCUMENT
    Dim oCtrlDef As ControlDefinition
    If oDrawDoc Is Nothing Then Exit Sub
    For Each oCtrlDef In ThisApplication.CommandManager.ControlDefinitions
        If oCtrlDef.DisplayName = "&Save Copy As..." Then
            oCtrlDef.Enabled = False
            'Call oDrawDoc.DisabledCommandList.Add(oCtrlDef)
    Next
End Sub
Tiffany Hayden
Tiffany_Hayden_
Found the issue! the display name is "Save Copy"
    ' DISABLES THE SAVE COPY AS COMMAND WITHIN A SPECIFIED DOCUMENT
        If oCtrlDef.DisplayName = "Save Copy" Then
        'If InStr(oCtrlDef.DisplayName, "Save Copy") > 0 Then
            Debug.Print oCtrlDef.DisplayName & ", " & oCtrlDef.DescriptionText
    Next
End Sub
Tiffany Hayden
Michael.Navara
Easier and language independent way is to use InternalName of button definition.
Dim cmdInternalName = "AppFileSaveCopyAsCmd"
ThisApplication.CommandManager.ControlDefinitions(cmdInternalName).Enabled = False
What is the internal name of command you can get from EventWatcher (tool from Inventor SDK).
Select UserInputEvents.OnActivateCommand and click the button in Inventor. In log window the internal name is displayed.
Tiffany_Hayden_
@Michael.Navara  Very Cool! Thanks so much!
Tiffany Hayden
