iLogic - Place with Mates while location is dependent on a parameter
waynehelley
Message 1 of 1
waynehelley
Hello all,
I have been using iLogic together with iMates for some time to automate assembly creation.  I have always used the follwing to automatically generate iMates on place.
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOccEnumerator As ComponentOccurrencesEnumerator
oOccEnumerator = oAsmCompDef.Occurrences.AddUsingiMates("file location and part number and extension), False)
The problem I have now is that Part B can contrain to either the left-hand or right-hand side of Part A dependant on if a parameter is set to 'Left' or 'Right'.
Hence for Part B, the composite iMate 'Part A to Part B' can always be used.
Part A contains 2 different composite iMates, 'Part A to Part B' and 'Part A to Right-Hand Part B'
So my logic will be (assuming Part A is already sat in the assembly and I am placing Part B)...
If Tier_Location="Left"
Place Part B while constraining to Part A mating 'Part A to Part B' to 'Part A to Part B'
Else
Place Part B while contraining to Part A mating 'Part A to Part B' to 'Part A to Right-Hand Part B'
End If
Doesn anybody know if there is any way to make this possible in iLogic?
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Replies (0)
