02:17 AM
- Mute
- Permalink
- Report
Hi.
I have a part that I want to keep as an ipt rather than an assembly. The part is a block with a thin plate attached either side. I have created the block as "Solid 1" then offset a workplane 0.1mm from the side and extruded a 2mm plate as "Solid 2 (then mirrored as part of solid 2).
I have a bit of code sending the part volume to a custom iProperty and this is in turn picked up by the idw in a text box.
The volume being picked up is "The Part". What I need to pick up is the volume for "Solid 1" only.
Is there a way I can set this or is there a bit of code that would do it?
Many thanks,
Terry
