- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I do have this rule. Pick part in assembly run rule and fill iproperties. Is it there illogic rule that can pick face and then fill iproperties something like in this rule. Thank you
Sub Main()
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim comps As SelectSet
Dim comp As ComponentOccurrence
comps = oDoc.SelectSet
'If there are selected components we can do something, otherwise we're done
If comps.count = 0 Then Exit Sub
Dim aDoc As DocumentsEnumerator
aDoc = oDoc.AllReferencedDocuments
Dim iDoc As Document
Dim cName As String
Dim cTS As String
Dim sTS As String
Dim FNP As Long
Dim cFNP As Long
Dim docFN As String
For Each iDoc In aDoc
sTS = iDoc.FullFileName
FNP = InStrRev(sTS, "\", - 1)
docFN = Mid(sTS, FNP + 1, Len(sTS) - FNP)
For Each comp In comps
cTS = comp.Name
cFNP = InStrRev(cTS, ":", - 1)
cName = Left(cTS, cFNP - 1)
If cName = Left(docFN, Len(docFN)-4) Then
'Set iProperty in each of the selected parts in assembly
iProperties.Value(docFN, "Custom", "MATERIAL") = "123"
iProperties.Value(docFN, "Custom", "MATERIAL DESCRIPTION") = "SOME DESCRIPTION "
End If
Next
Next
End Sub
