iLogic Pattern component issues
Message 1 of 8
I am trying to drive a pattern with iLogic and keep running into a problem.
I am working on a walkway which has 3 requirements based on slop angle.
1. 0-10° No Cleats
2. 10-15° Cleats spaced @ 450mm
3. 15-18° Cleats spaced @ 400mm
4. 18-20° Cleats spaced @ 350mm
I can make case 2, 3 & 4 work without a problem, but when I drive the model below 10° I run into an issue which I can't find a way to resolve.
My iLogic code removes the Cleat, and the Pattern below 10°
When I drive it back above 10° it adds the cleat and makes the pattern
All good so far...
Problem is, the parameter for the Cleat Spacing gets re-written as a number, rather than staying a linked parameter.
So when I drive it above 15° the spacing doesn't change.
Below is my iLogic. Does anybody out there have some suggestion as to how I can make this work?
Select Case PITCH
Case 0 To 9.9
	CLEAT_SPC = 450
	CLEAT_NO = Ceil((WW_LG - 300) / CLEAT_SPC)
Case 10 To 14.9
	Dim CLEAT_600 = Components.Add("CLEAT 600", "GW340.iam")
	Constraints.AddFlush("C BASE", "CLEAT 600", "BASE", "SW01 MESH", "MESH TOP")
	Constraints.AddFlush("C MID", "CLEAT 600", "CTR", "SW01 MESH", "MESH CTR")
	Constraints.AddMate("C EDGE", "CLEAT 600", "MID", "SW01 MESH", "MESH START", offset := - (CLEAT_SPC / 2))
	CLEAT_SPC = 450
	Dim CLEAT_Pattern = Patterns.AddRectangular("CLEAT Pattern", "CLEAT 600", CLEAT_NO, CLEAT_SPC, "SW01 MESH", "Z Axis", columnNaturalDirection := False, rowCount := 1, rowOffset := 1.0 in, rowEntityName := "Y Axis", rowNaturalDirection := False)
Case 14.9 To 17.9
	CLEAT_SPC = 400
Case >= 18
	CLEAT_SPC = 350
End Select
I have tried re-placing the cleat, and remaking the pattern for each condition, but run into issues there also...
Replies (7)
Message 2 of 8
Cleat PatternCleat Pattern
Here's an image to help show what I am trying to achieve...
Message 3 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please provide non confidential data to investigate?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 8
Hello Chandra,
I have attached a Pack & Go with the assembly currently shown above 10°
If you drive it by the iLogic Form, and keep it above 10° you will see that the Cleat Spacing updates for each condition.
When you drive it below 10° the Cleat, and Pattern, are removed.
When you drive it back over 10° the Cleat reappears ad the Pattern is reformed... all good so far.
However, the linked parameters for the Pattern, CLEAT_NO and CLEAT_SPC have become un-linked .
This means that the Spacing won't update for the other 2 conditions, 14.9 to 17.9, and >=18
Thank you in advance for offering assistance with my problem.
Darren Lammertse
Product & Process Design Engineer
Sayfa Systems
Message 5 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
File is missing. Can you please provide missing file? (SD907.20.ipt)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 8
Hello Chandra,
Missing file attached...
Message 7 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Thanks for providing missing file.
Select Case PITCH
Case 0 To 9.9
	CLEAT_SPC = 450
	Patterns.Delete("CLEAT Pattern")
	Components.Delete("CLEAT 600")
Case 10 To 14.9
	CLEAT_SPC = 450
Case 14.9 To 17.9
	CLEAT_SPC = 400
Case >= 18
	CLEAT_SPC = 350
End Select
While testing iLogic code, it is found that "CLEAT_SPC" is defined after creating new pattern in Case 10 To 14.9. That's why CLEAT_SPC is not changing for more than 15 deg.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 8
Hello Chandra,
I have found that the only way for this to work properly is to delete the part, and the pattern, for every case.
Then recreate the part, and pattern, after specifying the spacing. see below...
Select Case PITCH
Case 0 To 9.9
Case 10 To 14.9
	CLEAT_SPC = 450
Case 14.9 To 17.9
	CLEAT_SPC = 400
Case >= 18
	CLEAT_SPC = 350
End Select
I thought I would have been able to simply adjust the spacing after the pattern was created.
Perhaps I am not properly understanding the way iLogic works?
