how to i go down in a subassambly with Ilogic
Darkforce_the_ilogic_guy
Advisor Advisor
I have make a few code for doing stuff with illogic ... on part or assembly  but only at the first level
how word I get my Ilogic code to go look into all part and subassembly  all the way down the Assably structor?
and is there a way to look into the custom properties ?
And what about the file path ?
JamieVJohnson2
Assemblies have Definitions (AssemblyComponentDefinition) have a list of occurrences (think of each node in the browser tree).
Each Occurrence has a list of SubOccurrences (if assembly file based) OR
Each Occurrence has a Document reference, where you can get its Definition (and start a new dive from that file being the top).
So Occurrences = tree with grounded root
SubOccurrences = branch of tree.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
hozz__
I push parameter values down through an assembly like this...
Public Sub Main()
      'Assume that we won't be overriding the material right at the top level
      'so recurse down through the subassembly/part hierarchy
      'when drawer assembly Or_PanelMat True stop looking; when parameter does not exists children rule fails, cannot find parameter in children
      'when Or_PanelMat exists in all components rule runs as expected
      Call HandleSubAssemblies(ThisDoc.Document.ComponentDefinition.Occurrences)
End Sub
Public Sub HandleSubAssemblies(ByVal oOccurrences As ComponentOccurrences)
      'Called recursively for each assembly level
    Dim compo As ComponentOccurrence
    Dim MatThick As String
    For Each compo In oOccurrences
        If compo.DefinitionDocumentType = kAssemblyDocumentObject Then
                  'This is an assembly document so we want to go down to the next level
                  'unless it is marked as override material in which case we want to stop going
                  'down at this point
                  If Parameter(compo.Name,"Or_PanelMat") = False Then
                        'call this method recursively to go to a lower level
                  Call HandleSubAssemblies(compo.SubOccurrences)
        ElseIf compo.DefinitionDocumentType = kPartDocumentObject Then
                  'This is a part so if we aren't overriding the panel material
                  'for this part then we'll figure out the required material
                  '*** NOTE : if override material for the immediate parent assembly is true
                  '*** then we'll never get here
                        If Len(iProperties.Value(compo.Name, "Custom", "MThick")) > 6 Then
                              MatThick = Left(iProperties.Value(compo.Name, "Custom", "MThick"),
                                    iProperties.Value(compo.Name, "Custom", "PanelMat") = "PartVis"
    Next
End Sub
JamieVJohnson2
Your logic looks good to me.  Is this issue done, or did I miss the point, or is there another point to work out?
hozz__
It wasn't my thread, so I'm not sure...I was just posting a block of code that I have that answered the question
JamieVJohnson2
That's cool, for forum protocol, mark your posted code as the answer, so the next person researching your problem will know that's how you solved it.
Until next time,
