Ilogic. Parts being pulled through with a form.
kpulleyn
Observer Observer
kpulleyn
Observer
Observer
Hi, looking for some help,
Is it possible to pull a part into an assembly from vault using a drop down box on a form?
We are looking to pull from list of hundreds of a fans to place into an assembly.
Does anyone have an example of some ilogic code that might help us.
TechInventor20
If you have you're fans in one place it is possible.
It would be like this.
You have 2 rules. the first one you can put in your ribbon.
Rule 1:
Dim FileLocation As System.IO.DirectoryInfo = _
New System.IO.DirectoryInfo("Your route")
Dim Extension As String = ".ipt"
Dim fi As System.IO.FileInfo() = FileLocation.GetFiles("*" & Extension)
Dim MyArrayList As New ArrayList
For Each oFile As System.IO.FileInfo In fi
	MyArrayList.Add(oFile.Name)
Next
MultiValue.List("d0") = MyArrayList
Parameter("d1") = ("Your route")
iLogicForm.Show("Form 2")
Rule 2:
Route = Parameter("d1")
Part = Parameter("d0")
oPathandName = Route & Part
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,oPathandName)
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
The form:
