Creating a custom iProperty in a Virtual Component
jhunt3Z5BG
jhunt3Z5BG
I have been trying to create a custom iProperty in a Virtual Component (via iLogic) and have hit the wall. I know how to change the standard VC iProperties and create iProperties in a standard part via iLogic, but cant do it in a VC.
Here is a simpler version of my test code: Can anyone helpp me? I believe the issue is this part of the code below: "customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")", as this is setting the value in the assembly level by definition, not the VC.
'--------------------------------------Start of iLogic
'--------------------------------------Check that we are in an Assembly
oDoc = ThisDoc.ModelDocument
If oDoc.DocumentType = kPartDocumentObject Then
MessageBox.Show("You must be in an Assembly to run this rule!")
Return
Dim oAssDef As AssemblyComponentDefinition
oAssDef = oDoc.ComponentDefinition
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
NameOfVirtualPart = "TEST"
'--------------------------------------Add one virtual occurrence
Dim oNewOcc As ComponentOccurrence
oNewOcc = oAssDef.Occurrences.AddVirtual(NameOfVirtualPart, oMatrix)
Dim oCVirtualCompDef As VirtualComponentDefinition
oCVirtualCompDef = oNewOcc.Definition
'--------------------------------------Standard iProperties Populated
iProperties.Value(oCVirtualCompDef, "Project", "Description") = GoExcel.CellValue("AutoCAD Attributes.xls", "Summary", "B2")
'--------------------------------------Define Variable to Shorten Code Text Length
'--------------------------------------Check for Custom iProperties and add them if not found
'--------------------------------------Define iProperty Names as a String
Dim PropertyName1 As String = "FAMILY"
'--------------------------------------Adding Custom "CISCO_PART_\U+0023_FOR_ERP" iProperty
Try
          prop = customPropertySet.Item(PropertyName1)
Catch
          customPropertySet.Add("", PropertyName1)
End Try
''--------------------------------------Populate "FAMILY" iProperty
iProperties.Value(NameOfVirtualPart, "Custom", "NUMB") = "TEST" 'GoExcel.CellValue("AutoCAD Attributes.xls", "Summary", "E2")
JelteDeJong
you can try it like this:
Dim oDoc = ThisDoc.ModelDocument
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
    Return
Dim NameOfVirtualPart = "TEST"
Dim oNewOcc As ComponentOccurrence = oAssDef.Occurrences.AddVirtual(NameOfVirtualPart, oMatrix)
Dim oCVirtualCompDef As VirtualComponentDefinition = oNewOcc.Definition
iProperties.Value(oCVirtualCompDef, "Project", "Description") = "my test" ' GoExcel.CellValue("AutoCAD Attributes.xls", "Summary", "B2")
Dim customSet = oCVirtualCompDef.PropertySets.Item("Inventor User Defined Properties")
Try
    Dim prop As [Property] = customSet.Item("NUMB")
    prop.Value = "TEST"
Catch ex As Exception
    customSet.Add("TEST", "NUMB")
End Try
Jelte de Jong
Blog: hjalte.nl - github.com
jhunt3Z5BG
@JelteDeJong This is awesome...didn't think of trying it this way!
