iLOGIC Parameters
iLOGIC Parameters
MTTStructures
iLOGIC Parameters
MTTStructures
Hi I am playing with iLOGIC, but need to learn a lot.
I used some of Rob’c code:
Stock = iProperties.Value("Project", "Stock Number")
If Stock = "" Then
Stock = InputBox("Please Enter the iProperty Stock Number", "iProperties Check - Title Filled Out?", Stock)
iProperties.Value("Project", "Stock Number") = Stock
Desc = iProperties.Value("Project", "Description")
If Desc = "" Then
Desc = InputBox("Please Enter the iProperty Description", "iProperties Check - Title Filled Out?", Description)
iProperties.Value("Project", "Description") = Desc
It works well, but I need to modify it to List the current value (if any) and allow me to change it or accept the current entry.
Reason, I do a lot of “Save copy as” and need to change the values, if so desired.
Reg.
MjDeck
If you take out the If statements, it will show you the current value (whether it's blank or not) and allow you to change it:
Desc = InputBox("Please Enter the iProperty Description", "iProperties Check - Title Filled Out?", Desc)
Mike Deck
Software Developer
Autodesk, Inc.
MTTStructures
Thank you.
Such an easy solution.
There was a TYPO in my code which you corrected for me. The typo cleared the descption field every time, this confused me for a while.
Regards
Reg
