iLogic - Parameters tolerances
I would like to write some ilogic code to set-up the paramaters to median tolerance , then export part in *.step format and save in a specific folder.
I succeed to export files and save it as I want but I can't find the command lines to drive tolerances of parameters (min/max/nominal/median).
Could someone help me or indicate me where to find inventor ilogic command lines... If I-logic could be as easy as VB where it proposed a list of command as you start to typing the function..
Enjoy your Week-end,
John.
Vladimir.Ananyev
These lines should solve described task:
Dim oDoc as Inventor.PartDocument = ThisDoc.Document
Dim oParameters as Inventor.Parameters _
      = oDoc.ComponentDefinition.Parameters
oParameters.SetAllToMedian()
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Thanks for your help, it's works fine.
Please could you tell me where I could find which i-logic commands should be used related to inventor function? Is there a list of all i-logic / vb comands related to inventor?
John.
