Ilogic: open assembly from part
Message 1 of 11
Hi
I am trying to open an assembly from a part, and then use the filename from that part and save the assembly with the same filename.
Is that possible? and can I get the drawing file for that assembly also?
Replies (10)
Message 2 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
It always the case that parts can be opened from assembly and not visa versa. Unless the parts are added into assembly, part can not linked to assembly.
Similarly, a part or assembly can be opened from linked drawing.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 11
marcin_otręba
you can do it if on save of assembly tyou will write custom iproperty in each occurrance reference document like parent_ass  in which you will store assembly.fullfilename. Then you can read this iproperty and open it from part.
But in thiis scenario part cant be used in more than in 1 assembly.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 4 of 11
marcin_otręba
sorry i just read your post again,
do you want to create assembly wchich will be na,med as part with that part in it ?
Message 5 of 11
Yes exactly and use the title from the part on the assembly
Message 6 of 11
marcin_otręba
hi,
try
Dim name As String = ThisDoc.Document.FullFileName
Dim title As String = ThisDoc.Document.PropertySets(1).Item("title").Value
Dim ass As AssemblyDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject, , True)
ass.PropertySets(1).Item("title").Value = title
 Dim oTG As TransientGeometry
   oTG = ThisApplication.TransientGeometry
Dim oMatrix As Matrix
oMatrix = oTG.CreateMatrix
oMatrix.SetTranslation(oTG.CreateVector(0, 0, 0))
ass.ComponentDefinition.Occurrences.Add(name,oMatrix)
ass.SaveAs(Replace(name, ".ipt", ".iam"), False)
Message 7 of 11
That is exactly what I needed, thank you very much.
If I need to run an external rule on that assembly, how do I do that?
Message 8 of 11
marcin_otręba
Ilogic external configuration:
https://autodeskmfg.typepad.com/blog/2012/01/working-with-external-ilogic-rules.html
https://adndevblog.typepad.com/manufacturing/2015/01/add-external-ilogic-rule-to-event-trigger.html
i have polish version of inventor so i will not be able to post print screens to you because you will not understand 🙂
then change rule to this (it checks document sub type):
If ThisApplication.ActiveDocument.subtype<>"{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}" And ThisApplication.ActiveDocument.subtype<>"{E60F81E1-49B3-11D0-93C3-7E0706000000}" Then
Message 9 of 11
Maybe I was unclear.
I would like to do something like this:
iLogicVB.RunExternalRule("Configure") ' This rule should run on the assembly ass.SaveAs(Replace(name, ".ipt", ".iam"), False)
Message 10 of 11
marcin_otręba
Message 11 of 11
I solved it this way:
assembly = ThisApplication.ActiveDocument
auto = iLogicVb.Automation
auto.RunRule(assembly,"Configure")
Thank you for your help
