Run ilogic rule from another rule
amarcoc
amarcoc
Hi.
How can I run an external ilogic rule from another external rule?
Thanks in advance
Owner2229
You should check the snippets in iLogic. They're on the left. Under "Run else" you'll find this:
iLogicVb.RunExternalRule("ruleFileName")
 To run it for a sub-part:
iLogicVb.RunExternalRule("PartA:1", "ruleFileName")
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
amarcoc
Thank you.
That's it.
