Ilogic Noob trying to Wright a rule...... dont LOL to hard
Hello
so i am new to rule and ilogic
where do i start?
ok. i have a basic code that can change a length of 2 part base on what i type in "110 makes the parts 110in long"
so now what i am trying to do is add a "New Part" "i know how to do that" BUT if the "New Part" can go from 0-140in if it is over 140in the i need to add the same "New Part" to fill the space
e.g
the model i am building totals 200in in length i need 1 "New Part" to be at 140in and 1 "New Part" to be 60in.
but if the total length is under 140in then i just need 1 "New Part" at the length i type in.
if possible i would like to have this to all work automatically based on the Total length of the model
Justin.B.
Build both solids, then disable the second one if your dimensions fall under that range.
If partLength <= 140 Then
	Feature.IsActive("Extrusion2") = False	'Second solid not needed, disable it
	part1Size = partLength			'Part 1 is the only dimension needed
Else
	Feature.IsActive("Extrusion2") = True	'Activate second solid if length is over 140
	part1Size = 140				'Limit the first part to its max length
	part2Size = partLength - 140		'Set the second part to the remainder
End If
thanks i will try it.
Justin  douse this look correct
If Parameter("Awning Perf:1", "PerfLengthW") <= 140 Then
     Feature.IsActive("Awning Perf:1", "PerfLengthW") = False
 Parameter("Awning Perf:1", "PerfLengthW") = TotalLength - 2.75
 Else
	 Feature.IsActive("Awning Perf 2:1", "PerfLengthW") = True
	 Parameter("Awning Perf:1", "PerfLengthW") = 140
	 Parameter("Awning Perf 2:1", "PerfLengthW") = TotalLength - 2.75 - 140
End If
