iLogic MultiValue.FindValue for text
dusan.naus.trz
Advisor Advisor
dusan.naus.trz
I think the functionality doesn't support text. Is it true? Not supported for text?
MultiValue.SetValueOptions(True, DefaultIndex := 0)
'OK
'Try
'	p1="test"
'	m1 = Parameter.Param(p1)
'Catch
''	Create Parameter
'	op1 = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters.AddbyExpression(p1, 4.0, "mm")
'End Try
'MultiValue.SetList("test", 4.0, 0.75, 1.0, 1.25)
'If MultiValue.FindValue(MultiValue.List("test"), "=", 100) Then
'MessageBox.Show("Value found", "Title")
'Else
'MessageBox.Show("No match", "Title")
'End If
'BAD Try p1="test" m1 = Parameter.Param(p1) Catch ' Create Parameter op1 = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters.AddByValue(p1, "red", "Text") End Try MultiValue.SetList("test", "red", "yellow") If MultiValue.FindValue(MultiValue.List("test"), "=", "red") Then MessageBox.Show("Value found", "Title") Else MessageBox.Show("No match", "Title") End If
It hasn't written me a mistake in English yet. 🙂 And I have an English language version.
Converting red to Boolean is not valid.
dusan.naus.trz
I did it differently, but I would still like to know if the functionality supports text. Back to the query at the beginning.
Dim sValue As String
sValue = "red"
For Each oItem In MultiValue.List("test")
	If oItem = sValue Then
	oFlag = True
Next
If oFlag = True Then
MessageBox.Show("Bingo! " &  sValue & " is in the list.", "iLogic")
Else
MessageBox.Show("Sorry, " &  sValue & " is NOT in the list.", "iLogic")
JelteDeJong
try it like this:
sValue = "red"
If (MultiValue.FindValue(MultiValue.List("test"), "=", sValue) = Nothing) Then
Else
Jelte de Jong
Blog: hjalte.nl - github.com
dusan.naus.trz
Hi, I really like the simplicity. It is very practical. Thank you.
JelteDeJong
to be honest, if I would see this in any code I would not be happy. Writing code is not that difficult but writing readable code is much more of a challenge. And I did not succeed here I think. The following would be much better I think.
sValue = "Red"
If (MultiValue.List("test").Contains(sValue)) Then
Else
Jelte de Jong
dusan.naus.trz
That's great. When the code is simple, then it is fast in greater use. Thank you for the different variants. Different perspectives on the solution are very beneficial.
