- Mute
- Permalink
- Report
I think the functionality doesn't support text. Is it true? Not supported for text?
MultiValue.SetValueOptions(True, DefaultIndex := 0) 'OK 'Try ' p1="test" ' m1 = Parameter.Param(p1) 'Catch '' Create Parameter ' op1 = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters.AddbyExpression(p1, 4.0, "mm") 'End Try 'MultiValue.SetList("test", 4.0, 0.75, 1.0, 1.25) 'If MultiValue.FindValue(MultiValue.List("test"), "=", 100) Then 'MessageBox.Show("Value found", "Title") 'Else 'MessageBox.Show("No match", "Title") 'End If
'BAD Try p1="test" m1 = Parameter.Param(p1) Catch ' Create Parameter op1 = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters.AddByValue(p1, "red", "Text") End Try MultiValue.SetList("test", "red", "yellow") If MultiValue.FindValue(MultiValue.List("test"), "=", "red") Then MessageBox.Show("Value found", "Title") Else MessageBox.Show("No match", "Title") End If
It hasn't written me a mistake in English yet. 🙂 And I have an English language version.
Converting red to Boolean is not valid.
