iLogic Multi-Value
iLogic Multi-Value
Cosmin_V
Message 1 of 9
iLogic Multi-Value
Cosmin_V
Hi
Can somebody help me whit this rule?
I have a multi value User Parameter, named "Number_Of_Holes" which is a Circular Pattern.
And one User Parameter, named "Hole_Angle".
I need the User Parameter "Hole_Angle" to be = whit a multi value of all numbers from 0 to "Number_Of_Holes"/360.
Many Thanks!
Replies (8)
Message 2 of 9
johnsonshiue
Hi! Let me confirm with you what you are looking for. "Number_Of_Holes" is a unitless parameter has a list of predefined integer values from 0 to 5 for example. You want an angular user parameter, "Hole_Angle" equals to 360 divided by "Number_Of_Holes."
Shouldn't "Hole_Angle" = 360/Number_Of_Holes?
Many thanks!
Software Test Engineer
Message 3 of 9
Cosmin_V
Yes, but, if for example "Number Of Holes" = 20
then if  "Hole_Angle" = 360/Number_Of_Holes(20)
"Hole_Angle" = 18
But I will like the multi-value "Hole_Angle" = All numbers from (0 to 18)
"Hole_Angle",  "1",  "2", "3", "4"...…."16", "17", "18")
Or if for example "Number Of Holes" = 25
then if "Hole_Angle" = 360/Number_Of_Holes(25)
"Hole_Angle"= 14,4
But I will like the multi-value "Hole_Angle" = All numbers from (0 to 14 or 15)
Like This....MultiValue.SetList ("Hole_Angle", "1", "2", "3"....."13", "14")
I hope is understandable
Many Thanks!
Message 4 of 9
philip1009
Could you provide a sample of what you're trying to achieve?  It seems to me that what you want is when the user puts in a number of holes, you want a list of all possible angles divided by the numbers between 1 and the number of holes the user entered.
If user puts in 18 then you want a multi-value list with these angle values, 360 divided by 1 thru 18:
360
180
120
90
72
60
51.42857142857143
45
40
36
32.72727272727273
30
27.69230769230769
25.71428571428571
24
22.5
21.17647058823529
20
Message 5 of 9
johnsonshiue
Hi! I think it is doable. Essentially, you want a dynamic list depending on another parameter or an equation. In iLogic, you can use SetList command to set the list of numbers. I guess you want to build the list by using a Loop, starting from 0 and ending with the last angular value.
Many thanks!
Message 6 of 9
Cosmin_V
Exactly, but how can that be done?
I started to set manual the multi-value of "Hole_Angle"  every time the "Number_Of_Holes" is different but that will be a very long code.
Message 7 of 9
philip1009
It's a lot easier than you think.  I named the Unitless Parameter HoleQty, and my angle list HoleAngle, it's recommended to use camel case to name your parameters and variables instead of using _ all the time.
Here's the rule:
'Reset user input if less than 1 to eliminate errors
If HoleQty < 1 Then HoleQty = 1
'Recreate a new ArrayList
Dim lisAngle As New ArrayList
'Start a loop going from 1 to user input
For i = 1 To HoleQty
	'Add the current value dividing 360 to the list
	lisAngle.Add(360 / i)
	'Loop to next possible entry
Next
'Set the multi-value list from the ArrayList
MultiValue.List("HoleAngle") = lisAngle
Here's the rule if you don't want notes:
Next
After creating the rule, go to  Manage>iLogic>Event Triggers on your ribbon and drag your rule under Any Model Parameter Change:
Message 8 of 9
Cosmin_V
hi
Thank You, philip1009
But is not Working….
 have a problem whit this Line
Did I mention the "HoleQty" is also a Multi-value...I think that is the problem..
Message 9 of 9
philip1009
Mutli-Value list isn't the problem.  It looks like your code is longer than what I wrote.  Are you using "i" for something else before it's used in the HoleQty loop?
Maybe try this code re-defining "i" before using it:
Dim i As Integer = Nothing
Next
