iLogic. Move a drawing file
smart-cad
smart-cad
Good afternoon everyone!
Maybe someone knows ...
How do I move a drawing file?
Dim Filename_and_Path_start As String
      'Dim Filename_and_Path_end As String
Dim Path_end As String
Filename_and_Path_start = ThisDoc.Path + "\DATA\Drawing_1.idw"
Filename_and_Path_end = ThisDoc.Path + "\Drawing_1.idw"
                            InventorVb.Application.FileManager.MoveFile("Filename_and_Path_start", "Path_end")
WCrihfield
Similar to what I posted within your other similar post.  You can use the System.IO.File.Move()
Dim oOldNamePath As String = "C:\Temp\MyFolder\MyDrawing.idw"
Dim oNewNamePath As String = "C:\Temp\MyDrawing.idw"
System.IO.File.Move(oOldName, oNewName, False)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Here's another similar method, that can be used the same way from within iLogic (vb.net):
FileIO.FileSystem.MoveFile()
Wesley Crihfield
smart-cad
My.Computer.FileSystem.MoveFile(Filedata, Filework, False) - works well !
Thank you so much )))
