iLogic. Copy a drawing file in one folder and save it in another folder
smart-cad
smart-cad
Good afternoon everyone!
How can I copy a drawing file in one folder and save it in another folder?
Dim Filedata As String
Dim Filework As String
Filedata = ThisDoc.Path + "\DATA\Drawing_1.idw"
Filework = ThisDoc.Path + "\Drawing_1.idw"
Select Case OPTION_C
	Case "OPTION-C0"
	InventorVb.Application.FileManager.DeleteFile(Filework)
	Case "OPTION-C1"
	ThisApplication.Documents.Open(Filedata, False)
	ThisDoc.Document.SaveAs(Filework, True)
	ThisDoc.Document.Close(True)
	Case Else
		'MessageBox.Show("***", "Title")
End Select
Accepted solutions (3)
WCrihfield
You can use the following method:
Dim oOldNamePath As String = "C:\Temp\MyFolder\MyDrawing.idw"
Dim oNewNamePath As String = "C:\Temp\MyDrawing.idw"
System.IO.File.Copy(oOldNamePath, oNewNamePath, False)
System.IO.File.Copy()
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Here's another similar method that can be used in the same way in iLogic (vb.net):
FileIO.FileSystem.CopyFile()
Wesley Crihfield
smart-cad
My.Computer.FileSystem.CopyFile(Filedata, Filework, False) - works well!
Thank you so much )))
dusan.naus.trz
I love you all. I love this site. It's so inspiring. Thanks for being here guys.
