iLogic - Model State - Lower Level Assembly
JKunHN5NJ
JKunHN5NJ
I am trying to use iLogic in a top level assembly, to change the model state of a lower level assembly.
I have started off with this code, but obviously this is editing the top level and not the lower.
The top level assembly does not have model states.
MultiValue.SetValueOptions(True, DefaultIndex)
MultiValue.SetList("BASE_TUBE_NUMBER", "13.50 - 01000", "13.50 - 01025")
Select Case BASE_TUBE_NUMBER
Case "13.50 - 01000"
	ThisDoc.ActiveModelState = "master"
End Select
How do I link this to the lower levels?
dalton98
To change the active model state of a component use this:
Component.ActiveModelState("Part1:1") = "Master"
 If the model state names are the same for assembly and part the 'Link Model States' ribbon api seems to work ususally.
