ilogic Math Tan
ilogic Math Tan
ilogic Math Tan
ilogic is calculating tan/sin/cos/aTan/aCos/aSin incorrectly. I dont know where to start to fix the problem
e.g.
MessageBox.Show(Atan(35))
Answer = 0.4738... when it should be 0.7002....
Any ideas anyone?
Vladimir.Ananyev
MsgBox(Atan(35)) gives the result  1.54223266895614 rad.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
jdkriek
Any ideas anyone?
I think you are looking for Tan and results in degrees
Tan(35) results in 0.4738 Radians (which is what you are seeing)
Convert Radians to Degrees and you will see 0.7002 Degrees
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
adam.nagy
Autodesk Support
Autodesk Support
Did Jonathan answer your question?
If so could you please set it as an accepted solution?
Thank you,
Adam Nagy
Autodesk Platform Services
Sorry, i didnt get notified through email about the 1st responce. Yes that answers my question perfectly Thanks a lot!  🙂
jdkriek
Glad that explained it for you 😉
Jonathan D. Kriek
