iLogic material update
m_hermann
Message 1 of 16
m_hermann
Smiley Embarassed
i use this code in a small form:
MultiValue.List("Material")=iProperties.Materials'
iProperties.Material=Material
iProperties.Value("Custom", "Material")=Material
that works fine, the material change is correct.
But if i change the material from the apperentice browser my iLogic form displays only the material from fxParameter, means
there is no update.
How can I fix this?
thx
Michael
Replies (15)
Message 2 of 16
hi!
I dont have a same version of inventor, but i think the problem is this line of code? delete them
Message 3 of 16
m_hermann
Hi, thank's for your answer
no, this line is needed, nothing works without that only the material browser is not beeing updated and if i Change am material from the browser, my ilogic has the 'old' material
Message 4 of 16
With your rule it's the user parameter who control your material, what do you want to make?
Message 5 of 16
do you add a event triggers of your rule if material change?
Message 6 of 16
m_hermann
yes i added triggers. I attached the document and a document with screenshots.
If i change the material from browser, my iLogic displays the former material. I think i need to update the fxParameter but how?
(sorry for my bad english)
Message 7 of 16
i use inventor 2013 😞 i cant open your file
Message 8 of 16
m_hermann
Inventor 2013
Message 9 of 16
m_hermann
Spoiler
Hello everyone,
is there anybody who knows a solution for my problem?
PLS help.
Message 10 of 16
MultiValue.List("Material") = iProperties.Materials
MyMaterial = Material
iProperties.Value("Custom", "Material") = MyMaterial
iProperties.Material = MyMaterial
iLogicVb.UpdateWhenDone = True
Message 11 of 16
m_hermann
thx for your quick help. That works not bad but:
now i'm only able to change the material from my iLogic or fxParameter. Not in phys. Property and not in
Material browser.
How can i fix it that i can change the material everywhere?
Message 12 of 16
add Material rule to the event triggers "Any Model Parameter Change"
Message 13 of 16
For what do you use a form???
Message 14 of 16
m_hermann
I know what you  mean, do it in this way or do it in the other way but not mix it !?
We use the form to make all necessary iProperty inputs (20) and change the material in one way. In the form we display also the
weight, so we change the material if we get the correct weight.
When the input is done sometimes it happens that someone has to change the material without the form (its faster), or we have to
control the physiks, so we change the material in the iProperty.
Message 15 of 16
i have maybe a solution for you, try this
Message 16 of 16
m_hermann
yes that's it. It works very fine.
Many thank's.
