- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there any way to force an update of mass property values of a component from within an iLogic routine?
I am trying to produce a calibration chart showing the volumes of an irregular shaped object by taking incremental slices off the component and accessing the "volume" of the remaining portion, then writing the the results to an external file - All from within a "For - Next" loop.
The main routine works O.K. but the resultant chart only shows the original starting volume for each slice instead of the required reducing volumes.
I am a novice with iLogic and can only assume that I must somehow "update" the mass properties of the sliced object before reading its new volume on each pass - Any advice on how to achieve this would be appreciated.
